How will replacing the standard bearings with precision bearings in a typical Porter Cable style router improve the runout and overall performance if at all? Is it possible? Is it just a simple swap? Has anybody done this? If so, what was your experience and results? Thanks! |
| Hi NC Cams is the guy you need to answer this question as far as I can tell he’s a bearing guru. I’d like to see a “ask the experts forum” on this site, your type of question can only be answered by such a person in my opinion. I don’t know if it is ok but if you don’t get a response to this do you think it would be ok to send a pm to ask for help on these occasions or would that just be bad manners? John |
| Your so controversial Madclicker lol. I would have to agree with your point once again. How much run out we talking about? If you are having problems I would think it would be more to do with the bearing housing rather than the bearing. I had a cheap router on my machine for a little while and had all sorts of problems till I shimmed the bearing housing. Ran like a dream after that. John |
| You have me pegged old man......wait, can I say old man???? The only way I learn anymore since I graduated is to question and read. As far as a wood cutting routers runout, someone has to convince me I gotta stop cutting to change bearings????? Geez I have a router that has burned out bearings and I can't find time to fix it even though I have the bearings.
__________________ Steve DO SOMETHING, EVEN IF IT'S WRONG! |
| Hey I’m only 41 if I was over sensitive …….(did a quick edit ) Unfortunately I joined the zone at a time I was feeling old and knackered lol. Maybe it’s just the way you ask your questions and not the question at all.NOW BACK TO THESE BEARINGS John |
| Madclicker are you saying there is never any need for accuracy in woodworking? I knew an older carpenter once who's favorite saying was: "run it wild and cut it off later" or "that's what they make caulking for"! Even in woodworking sometimes close is not good enough. I manufacture competition rifle stocks and pistol grips. Now admittedly the outside shape tolerences I am not worried with as long as they say within .030" ! The internal cuts are a different matter all together. I have to fit existing screwholes, mortices, slots , islands and many times these internal configurations determine how the external shape fits the frame or action of a firearm. So yes, sometimes, woodworking needs to have tight tolerences. Mike
__________________ No greater love can a man have than this, that he give his life for a friend. |
#10
| I didn't ask the question but I think the general idea of it was will a higher quality bearing make a discernable difference. Particularly in the cheaper routers it's hard to see the manufacturer spending much on bearings. I don't think any one is expecting a better bearing alone to fix a poorly made spindle or collet. Or even fix a sloppy bearing housing. |
#11
| Although this is the woodworking forum, I would like to cut renshape and plastics for 3D contouring prototyping and model making. Since didn't see a plastics milling forum here, I thought this woodworking forum would be able to provide more relevant advice than the metalworking forums. So back to bearings... Last edited by biomed_eng; 10-27-2006 at 11:57 PM. |
#12
The question was about bearing runout and whether it was worth changing them to try to improve it. I don't think it is. If I had a router that had runout that affected my work quality I would take it back. I have 8 routers (9 counting the one that needs bearings) and none fall into this category.....not even the cheap chinese ones.
