Has anyone built a CNC router using CNC motion assemblies? - The kind using an extruded aluminum structure with internal ballscrew and rails? I just picked up 3 1500mm Techno-Isel Narrow slide assemblies off of ebay. http://www.techno-isel.com/Search5/BallScrew_Slides.htm I am wanting to us them in a dual XXYZ 4'x4' gantry type machine like the ShopBot. Anyone know if they are rigid on their own or should I reinforce them with other rails. The photos on the site show them mounted to each other, but I wonder if they can withstand the force of cutting. Thanks |
| Are they telescopic? If not, I think they'd be plenty rigid, if so, may still be good enough. If they are telescopic, do a deflection test by rigid mounting the fixed end, and placing weight on the free end. Check with a dial gauge to see if there is any deflection. If you don't have a dial gauge, rig up a bracket that extends a bolt to the flat surface to be tested against. Extend the bolt so that a .004 or so feeler gauge just slips underneath. Once extended, it should still just slip underneath if there is no deflection. Start off with the .004 so that you can go down in size to find out the true deflection if any.
__________________ Stop talking about it and do it already!!!!! (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Linear Motion FAQ | Cutters Cove | DIY-CNC Router Table Machines | 6 | 09-30-2009 01:36 AM |
| Inexpensive Linear Slide Assemblies? | Homl | DIY-CNC Router Table Machines | 15 | 06-03-2004 01:05 AM |
| Structural Debate: The Best Linear Motion Method | CNC Brute | DIY-CNC Router Table Machines | 3 | 11-22-2003 10:10 AM |
| 8020 linear motion products | bb99 | DIY-CNC Router Table Machines | 2 | 11-08-2003 02:21 PM |
| Using 80/20's Linear Motion | EvanRobert | DIY-CNC Router Table Machines | 5 | 07-01-2003 02:56 PM |
