I have built a desk top cnc router, I have stepper motors etc., I am looking at controllers, one that looks interesting offers for options an on board g code processor, and an rs-232/rs-485 serial interface, are these desirable options? Thanks Terry |
| Only if the control software your using supports them. Sounds proprietary to me.
| Controllers can be built many ways, look at control software; see if there is one you like over others and build around that. ger21 is right some control software can so that but I see the best being ethernet its much faster then RS-232 and simpler to set up. As for the g-code processor that is normaly done on the design side on your desktop and the CNC controller just reads the code
__________________ I'm not lazy..., I'm efficient! HAAS GR-408 |
| The quickest (and least expensive) route is to use what hundreds of other builders use. A PC parallel port(s) to some form of interface card/box driving off-the-shelf stepper driver. The controller software runs on the PC and sends Step & Dir signals for up to 6 axis. The interface unit gives you isolation and buffereing for inputs and outputs and helps with the integration (places to connect the wires). For controller software see: www.machsupport.com [MACH3] For motor controllers (depending on your motors) see: www.Xylotex.com or www.HobbyCNC.com or www.GeckoDrives.com You can buy the electronics pretty much done for you. Including power supplies and even complete power supply/motor driver combos. Hang around this place and ask questions. Just like the one you did ask. Rs232 or RS485 interface will drop you smack into a proprietary system. You then have fewer options for controller software (usually just theirs) and even fewer sources of help. Pick something hundreds have done and you have a potential of hundreds of ideas and support. Tom Caudle www.CandCNC.com |
