Old 01-12-2004, 10:05 AM
xairflyer's Avatar
xairflyer is on a distinguished road
Anybody seen or used these rails
Came accrss these, low profile rails and carriages.
Cost is very good I worked out that two 27mm (1 1/8") wide rails and two carriages on each 300mm long (for z axis) would cost £67.50stg from RS components who are not known to be cheap for anything over here.
Waiting on reply direct from IGUS.
The rails are available up to 3100mm (10ft ish).
They do a rail/carriage that is 80mm (3 1/4") wide, I wonder if you could use this a z axis on its own.?
http://www.igus.co.uk/Main_fs.asp?KA...O=START_DRYLIN
Old 01-13-2004, 04:56 AM
limbo is on a distinguished road
xairflyer,
Don't know about these specific bearings, but semi-professional machines like step-four use slide type bearings (the round ones). If its good enough for them.... . I've heard that slide types are less dust-sensitive than ball bearings and dampen vibrations better.
greetings,
John
Old 01-20-2004, 02:18 AM
bgriggs's Avatar
bgriggs is on a distinguished road
I used Igus slides on my CNC foam Cutter. I like them.
Bill
Old 01-20-2004, 03:18 AM
Hobbiest is on a distinguished road
Check out the w series slides from Igus. They are super stout and come in 40mm and 80mm wide. about $85 US I think per carriage and the rail is pretty cheap...$40 I think for 1440mm. Totally enough for a Z axis.
Stop talking about it and do it already!!!!!
Old 01-20-2004, 03:20 AM
http://www.drylin-w.com
How strong? (Linear rails, aluminum structure) WoodSnarfer Mechanical Calculations/Engineering Design 13 07-15-2005 11:29 AM
Add a second set of rails to X axis..need advice. bgolash DIY-CNC Router Table Machines 5 05-31-2005 07:11 PM
Joining two THK SHS15 rails PEU DIY-CNC Router Table Machines 9 05-24-2005 08:16 PM
Y-axis rails 2muchstuff Mechanical Calculations/Engineering Design 0 04-14-2005 10:01 PM
Shafts or rails? sjmarsha DIY-CNC Router Table Machines 5 06-30-2004 06:49 AM
