Old 10-17-2006, 05:54 PM
m!ni is on a distinguished road
Pitch / speed / accuracy ? ballscrew
Does the pitch on ballscrews effect the accuracy or just speed ?
Im tring to chose ballscrew for a 1000mm x 800mm cnc router table. Speeds not to important.
HELP !
Old 10-17-2006, 06:08 PM
ger21's Avatar
Not accuracy, but resolution. But that's probably what you meant. The coarser the pitch, the less resolution you'll have. But unless you're direct driving a screw with over 25mm pitch, you should have enough resolution, depending on your requirements of course.
Don't discount the importance of speed, btw.
Old 10-20-2006, 07:12 AM
Thanks. So would somthing like this ballscrew be good for a 1000mm x 800mm router table ?
Lead; Right Hand
Diameter; 16mm x 5mm lead
Spindle overall length; approx 800mm (31 1/2")
Spindle ball track length; 800mm (31 1/2")
Max stroke length; n/a
Weight; 1.6kg (1.7Lb)
Packed Weight; 2kg(4.4Lb) (plastic tube
I want to use the same ball screw for x,y, and z, to make ordering parts easy, is that ok ?
Old 10-20-2006, 10:08 AM
project5k's Avatar
project5k is on a distinguished road
theres no reason not to use the same screw for all 3 if it will work in your application.. but it sounds like you will have more screw that you need on a couple axis,, this is fine, just a little wastefull... you might save a little $$ if you go with a little shorter screw on the shorter axis.. if that matters to you.. but i do like the idea of using all the same screws, and maby you can get a discount for ordering more than 1 of the same thing... tho normally the qty discounts dont kick in till something like 5 or more in my experience...
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
