Old 01-09-2004, 12:20 AM
wakeboard is on a distinguished road
Questions
Hi everyone what an excellent site. I was wodnering anyone had a link to a place were they sell those black chain like structures where you pass cables through them and they dotn get tangled in your machine...they look like big black bicycle chains. If anyone can get a link i would appreciate that.
My second quesiton is if it worth getting a controller for my router...or should i get an adjustable router?
Also what router would you recomend for cutting aluminum and carbon fiber and lexan and plastic?
and also does a system with 2 lead screws help in anythign or jsut go with one lead screw for the x-axis soem othe person one htis forum did 2 lead screws in on the x-axis and if there is any advantage.
Thank you for all your help I am going to be building a CNC router soon!
Old 01-09-2004, 01:13 AM
steveald is on a distinguished road
Try http://www.igus.com/echain.htm for e-chain.
For a router I would recommend a Porter-Cable 3.25HP variable speed router. That's the router most commercial router tables use. I have used one for 10 years now (not the same one, but the same model) on several different tables. I use a Bosch 1617EVS 2.25HP router on my homemade 2x2 table to cut 1/2" aluminum, but I have a Porter-Cable to put on my 4x8 when it's finished.
Steve
Old 01-09-2004, 07:03 AM
ger21's Avatar
Also look at the new PC 892 2 1/4 hp variable speed. More power than the old 690, and much lighter than the7518 mentioned above.
Old 01-09-2004, 07:08 AM
chadwiggan is on a distinguished road
CABLE CARRIER AND MANAGEMENT SYSTEM
http://www.kabelschlepp.com/robotrax.htm
TRY THIS IT WILL BE ALOT CHEAPER THAN IGUS
CHADWIGGAN
Beginner Questions dfranks CNC Plasma and Waterjet Machines 6 06-12-2005 10:40 AM
Work has commenced, many questions Tabor DIY-CNC Router Table Machines 3 09-21-2004 11:46 AM
Some Gecko 201 Questions mikie Gecko Drives 3 08-09-2004 11:40 PM
Questions for starting and a formula ... elenabux General Metal Working Machines 3 07-17-2004 06:54 AM
A few honest questions HuFlungDung CamSoft Products 8 06-15-2004 06:24 PM
