Old 10-09-2006, 07:38 PM
pvogtcharlotte is on a distinguished road
OK Now what? Can anyone help with software?
Hi Y'all,
Thanks to help from Campbell designs on the interface board, John at Kellinginc for assisting with the stepper for my Z-axis, and alot of parts from a place called Interstate Salvage, I have finally completed my CNC router. Using Mach 2 software, I have engraved my kids names in a block of wood (much to their delight).
Now, it's time for the real fun...
Can somene please tell me what everyone is using to create toolpaths with? I have Autocad and Rhino, but no obvious way to generate toolpaths for my parts. I would like to do things like Guitar bodies etc.
Thanks for any suggestions,
Paul
Old 10-09-2006, 09:18 PM
ger21's Avatar
Simply draw the actual toolpaths in either AutoCAD or Rhino (2D drawings), save as .dxf, import the .dxf into Mach2 and convert to g-code. If you want more control, you can use something like SheetCAM. www.sheetcam.com
If your using AutoCAD 2002 or newer, I wrote a macro that will export g-code from AutoCAD. http://www.cnczone.com/forums/showthread.php?t=8226
Old 10-10-2006, 05:59 PM
There mus be something better....
Ger21,
Thanks for the response. I would expect that there is something out there that more automated/sophisticated
than drawing the tool paths manually. What do people
do to machine arbitrary cuved surfaces created in programs
like Rhino?
Thanks for any help,
Paul
Old 10-12-2006, 09:55 PM
ger21's Avatar
What I meant is that if you've drawn the part, then the drawing IS the toolpath. If your'e talking about a 3D model in Rhino, and want to cut out a profile, then you'll need to create 2D drawings of the profile. If you're talking about 3D routing, like a carved top guitar body, maybe something like MeshCAM. www.meshcam.com
More expensive softwarelike Visual Mill can cut theproflie directly from a 3D model.
Old 10-12-2006, 10:09 PM
MeshCam: Looks like the tip I was looking for!
Gerry,
Thanks very much for the tip. I looked at the link, and was impressed. Number one, it's affordable. Better yet, it has a 60 day free trial!!
Thanks very Much!
Paul Vogt,
Charlotte, NC
