Old 01-04-2004, 06:24 PM
xairflyer's Avatar
xairflyer is on a distinguished road
What size drive screw?
I have both 6mm and 8mm stainless all thread that I can use for my drive screws.
Is a fine thread (more tpi) not better than a large say 1/2 screw with less threads ?
I would have thought my 6mm 26 odd tpi would give me a lot more acurate cuts or am I looking at this total wrong.
Old 01-04-2004, 07:23 PM
balsaman's Avatar
balsaman is on a distinguished road
Yes and no. The lower pitch screws do a few things. One is increased force. This at the expense of some speed. Another is increased resolution. Do not confuse this with accuracy. Even with 10 TPI screws and 200 step steppers running at full step you will get .0005" per step. Your machine, even if very tight, will have more slop in it than that, so going to a finer pitch will not improve the accuracy of the machine.
Either screw will work fine. I would use the coarser one, just to get a little more speed.
Eric
I wish it wouldn't crash.
size of drive for enitre unit CNC Darren Servo Drives 0 03-20-2005 11:53 AM
for engraving pcb which is a good thread size for the lead screw? NickLatech DIY-CNC Router Table Machines 11 01-17-2005 08:37 PM
size of 4th axis drive converterk AjaxCNC Control Products 10 06-07-2004 10:01 AM
Belts versus Direct Drive bsmith DIY-CNC Router Table Machines 12 06-06-2004 10:09 PM
drive screw sizing Dan S DIY-CNC Router Table Machines 2 11-09-2003 07:02 PM
