Old 01-04-2004, 04:26 PM
Woodie1 is on a distinguished road
Anti-Blacklash Nut
I have a Kuroda Ball Screw with a nut. Is there anyway to tell if it's a Anti-Blacklash nut? The numbers on the nut are 20-2,5 C1S and 92E 0962 if that means any thing.
Old 01-04-2004, 08:10 PM
HuFlungDung's Avatar
Moderator
Hi Woodie1,
You could test it with a dial indicator (all you guys should have one of these by now, they're available cheap )
Clamp the ball nut tenderly in a vise, and pull the screw axially, with the indicator against the end of the screw. If it moves, it's not got zero backlash.
Some ballscrews are custom packed with just the right size of ball to eliminate backlash, others have a two piece nut assembly which can be shimmed apart. Most likely you would have noticed this already.
Generally speaking, a zero backlash ballscrew has a firm feel to it, that is, the screw will not rock in the nut.
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
Anti - Backlash Nuts Mhiran DIY-CNC Router Table Machines 62 02-18-2010 08:55 AM
Anti backlash nut design nakchak DIY-CNC Router Table Machines 13 09-06-2008 06:32 AM
anti backlash nut? sixpence DIY-CNC Router Table Machines 13 07-18-2007 02:51 PM
anti backlash nut hpghost Linear and Rotary Motion 3 05-15-2005 09:16 PM
