Old 09-27-2006, 06:53 PM
Blacksunshine is on a distinguished road
Plasma-vs-Router
If I have a router cnc what do I need to convert it over to a plasma cnc, besids the plasma cutter?
Old 09-27-2006, 10:30 PM
project5k's Avatar
project5k is on a distinguished road
well you will need a way for the computer to turn on and off the arc, and a way to hold the torch to the z axis... long enough stinger cable on the plasma to be able to move around and not get tangled up... and depending on how your table is constructed possabley a different bed, or something that you can drop in over your existing bed, ie some wavy steel bars on edge...
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
Old 09-27-2006, 11:10 PM
andy_ck87028 is on a distinguished road
I'm no expert but from CNCzone, I got the impression that plasma heads move across the cutting area quite fast. I think I recall that gearing therefore tends to be different.
Some input from the plasma guys I guess would clear that thought up.
Andy
Drat, imperfection has finally stopped working!!
Old 09-27-2006, 11:26 PM
project5k's Avatar
i would tend to agree that you would want your feed speeds to be faster... whats your max IPM now?
Old 09-28-2006, 07:23 AM
massajamesb's Avatar
massajamesb is on a distinguished road
To the best of my understanding, you will need one of these.
I don't think MDF or balsa, nor any other wood will care much for your plasma sparks. Just my two cents.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
Old 09-28-2006, 10:12 AM
project5k's Avatar
this should be in every shop.... that reminds me, i gotta get one of thoes....
