  #13   Ban this user!
Old 09-26-2006, 08:58 PM
candle is on a distinguished road
it woulnd't expand infinitly or contract to zero would it?
you need to sacrafice some of axis travel for this setup
Old 09-26-2006, 09:40 PM
spalm's Avatar
Gold Member
spalm is on a distinguished road
http://www.cnczone.com/forums/showthread.php?t=5392
I was trying to find the thread about the cardboard folded bellows....
Steve
Old 09-27-2006, 09:53 AM
chuckknigh's Avatar
Gold Member
chuckknigh is on a distinguished road
http://www.cnczone.com/forums/showth...hlight=bellows
Bellows Origami
  #16   Ban this user!
Old 09-30-2006, 09:12 AM
project5k's Avatar
project5k is on a distinguished road
very interesting... i actually had a thought on how im gonna do mine.. im gonna stretch a cable inline over the screw, maby 1" above it or so, and thread the plastic slinky covered with something, maby a stocking, maby something else.. then attach both ends of the slinkey.. one to the frame and 1 to the gantry, and repeat for the other side...this will keep the slinky from drooping onto the screw, and will allow it to slide freely... ok, yea after a few thousand cycles the cable might cut through the slinkey, then i'll re think it... just an idea at this point anyway
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
  #17   Ban this user!
Old 10-04-2006, 04:38 PM
bigz1's Avatar
bigz1 is on a distinguished road
My ACME thread arrived today (I have had no end of trouble getting some). Attached image shows the results of testing my rubber CRUD CATCHER(Trade mark).The rod was covered in oil and crud and you can see how much was wiped in just 12". Its very Heath Robinson at present but their will be 2 of these either side of the nut with a faceplate to hold it in place. Rubber is from a bicycle inner tube and used a hole punch for the hole. Cheap as chips and simple.
Liam
  #18   Ban this user!
Old 10-04-2006, 10:12 PM
project5k's Avatar
bicycle inner tube huh? thats just crazy enough to work. i just cant get the image of a slinky bouncing around under my table tho......
"its slinky, its slinky, why dont you give it a go, its slinky its slinky, fun for a screw or DRO!"
hehehehe
  #19   Ban this user!
Old 10-04-2006, 11:05 PM
RLC RLC is offline
RLC is on a distinguished road
would something like this work? they are dirt bike fork boots, the only thing is the 2 ends are different sizes...just a thought
http://www.cycleconnect.com/shop/pro...&catalogId=212
Robert
  #20   Ban this user!
Old 10-05-2006, 08:54 PM
project5k's Avatar
i dont see why that wouldnt work, just so long as your sure about the total collapsed length and the expanded length, and that it will work with your setup...
  #21   Ban this user!
Old 10-05-2006, 11:51 PM
cbass is on a distinguished road
http://www.doityourself.com/invt/7446362
Carlo
  #22   Ban this user!
Old 10-06-2006, 11:36 PM
project5k's Avatar
hey now thats not a bad idea, the dryer looking hose.. light, cheap, and can get more later... hmmm seems easier than the slinky idea....
  #23   Ban this user!
Old 10-07-2006, 12:06 AM
