Hello all. I have just finished building a modified JGRO that will give me a working area of 2' x 4' and 6" of Z. I will be using a MAXNC CL motion kit I have had laying around. It uses NEMA 23 with 173oz of torque. I have tested the motors as-is and they move each axis very well, but now it has come time to fully hook them up which leads to my question. The steppers currently have about a foot of 22AWG wiring. In the case of the z axis, I will have to extend this to around 6' and was wondering if the 22AWG is fine, or do I need to change it because of the distance? I'm pretty good mechanically, but know nothing of electricity so any help would be appreciated. I don't want to fry a component or anything. |
| The resistance for 22awg is 16ohms for 1000 feet... so 6 feet would be 0.09684 ohms.... plugging into E = IR (Volts = Amps x Resistance) you get Volts = 3amps x 0.09684 or 0.29052 volts. So can you afford to lose 0.29052 volts to your steppers? Not sure of the voltage you are running but E x I = P (power) so at 36 volts and 3 amps at a continuous load you are dissipating 108 watts of power. Which shouldn't be too bad since the power is in steps not a constant. (and if I am wrong... someone will correct me!) |
