  #61   Ban this user!
Old 10-24-2006, 10:06 AM
wcarrothers1 is on a distinguished road
Proj.. I have no idea what you are saying in that last message...
I'm going to put foam bummpers or something at either end of X I think.. Hopefully the soft limits in mach work well..hehe
Anyway more pictures.. The machine is turning blue.. I'm thinking now I should have gone with red though..
b.
ID:	24526   Click image for larger version
  #62   Ban this user!
Old 10-25-2006, 11:58 PM
project5k's Avatar
project5k is on a distinguished road
i was making a bad joke about your rubber or foam bumpers at the ends of your travels... sorry, sometimes when i dont sleep i dont make sence...
Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
  #63   Ban this user!
Old 11-01-2006, 09:05 AM
Finally got my limit switches put in.
The pic is of the Y limit switches on the back of the stage.
I have the limits all in series normaly closed right now.
The pic shows the right and left limits (2) and 2 home switches on either side. The home's of course trip before the limits. My home switches are also wired in series NC and I have 2 of them so I will be able to home my machine to either side of the machine (if I want to move my 0 x and 0 y to the other corner of the table incase I move it to another part of my basement some day)..
I'll get a picture of my x limit swtiches tonight (batterys died in the camara)
But they run along the side rails of the machine. and are the roller ball type limit switches. I have a piece of aluminum bent in a small ramp shape at one end with slots cut in them for the adjustment screws so they can be moved up and down a bit on the side rails. When the ball on the limit hits the ramp it goes up and trips. I used 2 limit switches for the limits and one switch for the home which can be triggered at either end..
Also something I didn't think about when doing my home's on the mill.... Is the home switches only trigger 1 at a time (ie Y homes first then x ect) since that is the case.. You can wire them in series to a single input (rather then 2 separate ones) and save an input for something else. Perhaps the smarter people here already know that though..
Seems like it will work well..
if I torque on the tip of the router at full extention down (on Z) I can get ~.001 worth of movement according to my dial gage when it is centered on the gantry. Course the amount goes down a bit the closer it gets to either end
although most all the flex is in the Z it self and not the 1" supported bars of the gantry.. So I think I may some day build myself some end plates for Z to use the extra 1" bars I have around rather then the 3/4" bars I used.
Seems the amount of movement should not be enough to really bother upgrading unless it's a cold winter... Thing seems like it should run and cut up pieces very well..
I'm quite happy at this point with how things all work together..
b.
