  #13   Ban this user!
Old 11-06-2006, 03:50 PM
acondit's Avatar
acondit is on a distinguished road
Originally Posted by ger21 View Post
A simple pushbutton switch to toggle between axis is very simple to implement using the OEM triggers in mach3. Also, using screen designer, you can add large LED's on any screens you want to show the active axis.
Ger21,
I am actually using EMC2 so the features of mach3 are not relevant at the moment. I do like a lot of the features of Mach3 but I am not a windows fan.
I am actually exploring the use on a cnc equipped lathe to drive the lathe in manual mode without the computer attached. In addition to the encoder, my circuit board has a variable speed step generator that can be used as a powerfeed. I'm still testing.
Alan
