Old 12-29-2003, 10:40 AM
kayakman's Avatar
kayakman is on a distinguished road
Size limits vs stepper motorsize
Hi
I´m on the start to build my own router. I will build it in MDF board and are going to use motors like this
Astrosyn 23LM-C303-09 3,5 V/Ph 1,4 A/Ph
How big tabel can I build?
I would like to be able to rout workpieces that are about 1 meter x 1,5 meter.
Is this possible
How large motors do you need?
Old 12-29-2003, 10:53 AM
InventIt is on a distinguished road
I think the sizing of the motors has more to do with resistive forces acting against the motor ie: friction, inertia (weight of gantry, leadscrew, etc.) and needed cutting force. The size of the machine is only limited by your needs. Also the size of the motor may determine the max speeds of the machine.
Old 12-29-2003, 12:05 PM
balsaman's Avatar
balsaman is on a distinguished road
That is a pretty large machine. I would stick to 12x24" max unless you have big money for a drive system. Those steppers may move the machine around, but not too quickly.
What you learn on a small machine will make a larger machine posible. It is also very hard to make a machine that size rigid enough out of MDF.
Eric
I wish it wouldn't crash.
Stepper Motors size? mtsrose DIY-CNC Router Table Machines 7 12-14-2004 11:21 AM
How to figure needed stepper motor size? Hack General Electronics Discussion 4 07-19-2004 04:43 PM
Fun with floppy stepper and driver Konstantin General Electronics Discussion 5 03-08-2004 02:18 AM
how do i determine what size stepper motors to use? capitalv General Electronics Discussion 3 01-20-2004 03:22 PM
Z-axis...what size stepper ? dmoore3008 DIY-CNC Router Table Machines 1 05-08-2003 08:13 PM
