Old 12-28-2003, 08:06 AM
kayakman's Avatar
kayakman is on a distinguished road
Info needed on steppers
Hi can anyone tell me more about this steppermotors. I have found them in a plotter/printer and are thinking of using them in a 3 axis woodrouter/mill
Astrosyn Stepper Minebea 3,5 V/ph Type: 23LM-C303-10
Astrosyn Stepper Minebea 3,5 V/ph 1,4 A/ph Type: 23LM-C303-09 02235-60056
The steppers have 4 cables coming out of them
Are these steppers useable in a router project and what type of controller must I use?
Hope someone can help me
Happy new year / The CNC beginner with tons of projects waitíng for a CNCmill : )))))
Old 12-28-2003, 09:46 AM
balsaman's Avatar
balsaman is on a distinguished road
Do you know the amps per phase for the first motor?
The second motor will work nicely with the xylotex controller or any other bipolar controller.
Eric
I wish it wouldn't crash.
Old 12-28-2003, 10:37 AM
kayakman's Avatar
Info on Steppermotors
Many thanks for such fast respons balsaman, great forum!
The first stepperseems to be the exact same as te second with the difference that the second motor has a gearwheel on it. Othervise from this they look the same. Same size, equal amount of cabels out (4 cabels out, red, blue, black and green).
But you say they are bipolar. Do you know how much tourq they have or any further info?
Are you in to RC flying?
Old 12-28-2003, 11:44 AM
balsaman's Avatar
Do you have an ohm meter? Check the winding resistance.
Go to www.Astrosyn.com to see if you can find some more info.
Yes, I am into rc flying.
Eric
CNC conv. info help needed Texasj10 Shopmaster/Shoptask 7 03-12-2010 05:36 PM
Info needed for these servos Splint General Electronics Discussion 27 11-10-2008 04:24 AM
Lathe info needed kong General Metal Working Machines 2 06-01-2007 05:45 PM
help with info on steppers jleiwig DIY-CNC Router Table Machines 8 11-22-2003 09:03 PM
