Old 09-09-2006, 07:15 AM
Apples's Avatar
Apples is on a distinguished road
This router bit for aluminium? or not?
I need to buy a router bit for milling aluminium in my CNC wood router/plasma table. Will this be the right router bit for the job?
I am looking at getting the first one in the list. Part number TSR8 at $26.51 USD. It is an upcut.
http://www.ozrouterbits.com/html_rou...-sb-sbnfm.html
What machine feed speed should I cut at?
What should be the depth of my cut per pass?
Cheers
Peter
Old 09-09-2006, 10:00 AM
--colin-- is on a distinguished road
Sure, those cutters are for non-ferrous metals - aluminum, brass, etc. As for cutting speeds, take a look at ME Consultant software. It's a free application available at http://www.freedownloadscenter.com/B...onsultant.html
Seems to be pretty good for doing the feed/speed calculations.
Old 09-10-2006, 05:26 AM
Apples's Avatar
That link that you gave me does not work.
Peter
Old 09-10-2006, 08:20 AM
ger21's Avatar
http://www.cnczone.com/forums/showpo...2&postcount=10
