I was just thinking about creating a small tabletop CNC machine and was drawing a simple picture of the table when I began to think that the linear rails were redundant if I were to replace them with 1” Acme screws. I’d either drive the two screws using a timing belt or two servos. I’d use two AB nuts in place of the bearing blocks. Does anyone know how rigid 1” Acme screws are over a 24” distance? Also, what issues/problems to look out for? --bb99 |
| It might have a little run out in the screw and more side clearances than Thomson rods or rails and it would take a lot bigger motors to move it and have a lot of side wear on the nut witch would lead to a lot of backlash in a short period of time. Last edited by motomitch1; 12-26-2003 at 04:14 PM. |
| Not a real good idea, from the viewpoint of how Acme thread specifications are laid out. In pitchs finer than about 4tpi, the top of the crest, and the root of the thread, have a clearance of .010" (going from memory), which amounts to a .020" gap. So, depending on the backlash of the nuts, your gantry really has nothing to sit on. Add to that the additional wear of the nuts, and you have less bearing than ever. This built in clearance could add a lot of wobble to your gantry, the further you get from the screw location. Your idea might sort of work if you had zero backlash ball screws, though. However, even then, it would be best to have two ballscrew nuts per screw, in order to create some kind of a longer, stable base for your gantry.
| Thanks! Grate points you all make. I'll keep with the linear rails and forget the Acme screw idea. --bb99
__________________ There are 10 types of people in this world; those that understand binary and those that don't. |
| Ball screws, Acme screws, threaded rod | DJ Morrow | DIY-CNC Router Table Machines | 11 | 03-22-2007 01:39 PM |
| How strong? (Linear rails, aluminum structure) | WoodSnarfer | Mechanical Calculations/Engineering Design | 13 | 07-15-2005 12:29 PM |
| Question obout acme threaded rod (lead screws) | Hack | Mechanical Calculations/Engineering Design | 1 | 04-02-2005 01:12 PM |
| Linear bearing spacing & Sizing linear rails? | fyffe555 | DIY-CNC Router Table Machines | 3 | 12-07-2004 02:09 PM |
| Alternate Linear Rails?? | ehiebert | DIY-CNC Router Table Machines | 12 | 10-02-2003 10:36 AM |
