I ve attached a photo of my power supply box, Ive installed the 24v power supply, 6.5 amp fuse, power cord, 24v cooling fan, 3-axis xylotex board, cables supplied by xylotex for my stepper motors. Is it necessary to install a on-off switch and if so what would be the best type? Any suggestions would be appreciated. |
| Say, Where did you get the metal box?
__________________ Thanks Jeff Davis (HomeCNC) http://www.homecnc.info (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| the metal box was picked up at the local Home Depot, cost was I believe $21.00 it is about 6" deep & 12" wide has several 1/2" to 2" electrical knockout holes. As a matter of fact the knockout hole on side was the exact size of the cooling fan , So I mounted the Xylotex board on 1" long aluminuim spacer rod to get it perfectly in line with fan and help with cooling ..Jim Stidham |
| There needs to be some way to cut power to the box other than resorting to unplugging the unit. As Balsaman said an E-stop is a good idea, but even a basic toggle wall switch will work. A 15 amp household wall switch is 30 cents, a "real" e-stop switch is 100 times that, but it is industrial strength (with the industrial profit margin). Radioshack sells a 10 amp panel mount (read: easy to install) push button for $6 but the button is not oversized. Are there inquisitive kids around the shop? Maybe a keyed switch is in order along with a kill switch....whatever route you choose, yes, a master power switch is needed. |
| How does a power supply work. | ynneb | DIY-CNC Router Table Machines | 1 | 07-27-2011 10:40 AM |
| Diy Power Supply Choices | berin | DIY-CNC Router Table Machines | 11 | 07-13-2005 04:47 PM |
| 5 Volt Power Supply Tripping | murphy625 | General Electronics Discussion | 13 | 02-27-2005 10:05 PM |
| Is this power supply rating adequate? | jerryrigge | General Electronics Discussion | 3 | 11-25-2004 11:06 AM |
| Choosing a Power Supply for Retrofit? | pfeist | General Metal Working Machines | 4 | 05-23-2004 11:36 PM |
