Old 12-22-2003, 07:30 PM
samualt is on a distinguished road
How do I mount Acme/Ball Screws?
I see all these ads for acme and ball screws. Most don't come with end bearings, just the screw and the nut. Some acme/ball screws have non-threaded ends, some look like the thread goes to the end.
1. Do all proper screws have non-threaded ends (both ends) for bearings?
2. Do the bearings just press-fit on the screw shaft? Do you use a rubber hammer to tap them on?
3. Once you place the bearing on the screw shaft then what? Most bearings look very smooth and round with no mounting hardware.
I have heard people say they just drilled a hole for their bearing in their aluminum plate. Are you press fitting the bearing into the plate? That just doesn't sound like it will hold. Is it a tapered precision hole in the aluminum plate? Why doesn't it just fall out?
If you use a "Base-Mount Ball Bearing" then you have some nice bolt holes to mount the thing.
4. If the screw is threaded all the way to the end how are you going to put a bearing on that end? Is that screw useless?
5. If the non-threaded end of a screw is exceptionally long (like 6 inches or more) is it OK to use a compound-miter saw to hack off some of it?
6. Many pictures of ball or acme screws are very bad. The Nook ball screws always show the nut where you can't see any way to bolt something to it. Do all ball-nuts and acme-nuts have a round or square flang with bolt holes?
7. Am I correct in assuming that the non-threaded end of an acme/ball screw with a grooved keyway is for a motor coupler? Some just look like they have a groove for something.
8. Is there any hard and fast rule about the width of the screw? Like a large machine with a screw of 50" long should be at least 1" diameter. And a Z-axis screw should be at least 3/4" diameter for large machines?
9. I'm having a little trouble with my design. Mainly that I have 53.5" THK rails for the Y-axis (side to side), the Z-axis is probably going to be at least 5" wide. Am I wrong in thinking the screw should have 53.5" travel? Or should the minimum travel be larger?
10. Please answer any questions I wasn't intelligent enough to ask. LOL.
Any help appreciated...........Sam
Questions courtesy of 'Newbies-R-Us'.
Old 12-22-2003, 08:45 PM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
HuFlungDung will be with you in a moment
Old 12-22-2003, 09:01 PM
HuFlungDung's Avatar
Moderator
Hi Sam
Let it all out, its not good to let it build up inside you like this, until you just explode
1. It depends: if the design calls for support at both ends, then yes, it would be best if the ends were accurately turned to fit the bearings. This is the only risk, that the top of the threads will not be an accurate size to fit any commercial bearing that you can find. Rolled threads generally have poor control of the OD, unless some type of finishing operation was performed afterwards to flatten the top.
In some situations, if the slide is well supported already, and the screw overhang is not excessive, then you do not need an outboard bearing on the screw. The nut or the ball nut will be the sole support for the far end of the screw.
2. A light press fit is the ideal fit, if the bearing journals are accurately centered with respect to the screw thread axis. But, a slide on fit is usually .0005" or more "loose". If you like, you can apply a drop of Loctite (anerobic space filling compound) to "glue" the bearing to the shaft. When this hardens up, it is equivalent to a light press fit, but without the likely damage to the bearing (and seals) that you may cause with a hammer. This requires 350 to 400 degrees F of heat to melt apart again, and this much heat is not good for your bearings, so try to do it right the first time
3: Bearings are mounted in precisely machined bores or housings. They may be retained with spring retaining rings, or nuts, or held captive in a "sandwich plate". You can buy commercial bearings mounted in pillow blocks. These blocks may be cast iron or pressed steel flangettes. The bolts for the bearing then pass through these pillow blocks to hold the bearing in position.
4: You will have to have the end turned, if you cannot find a bearing to fit it as is.
5: Cut it off however you like.
6: I would say most ballnuts have some kind of mounting flange. An Acme nut may simply be machined from ordinary Hex or Square stock. For these, you could get a flange welded to the nut, and drill mounting holes in that. You might also create a "tie rod mounting sandwich" for such a nut, with 3 bolts straddling the outside of the nut, through a couple of washers drilled for them.
7: Yes, the keyway is for drive coupling or gear, timing gear, sprocket etc. Some light duty screws might have only a flat spot for a setscrew clamp. Keyless shafts can sometimes be driven with taperlock sprockets, which is a two piece assembly, consisting of a tapered hub which collapses onto the shaft as it is being tightened into the tapered bore of the overlying sprocket/gear. These will drive a light mechanism quite well, although a key is still desireable "just to be sure".
8: There is a rule, but I don't know what it is. I just make sure it's heavy enough
9: The screw should have as much travel as the slides can actually move. A 53" slide may only have 50" of travel, because of the width of the blocks.
10: too exhausted to go on.....
Old 12-23-2003, 01:19 PM
Bloy2004's Avatar
Fumbling Machinist
Jeff will be with you shortly.
Old 12-23-2003, 01:20 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
Below is one way you can mount a screw using two angular contact bearings. The bearing holes do not need to be press fit nor does it need to be pressed onto the shaft. Just a very close slip fit works fine.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Which Ball Screws to use? Willyb Linear and Rotary Motion 4 01-19-2005 09:49 PM
How Should I Mount Linear Encoders? lerman General Metal Working Machines 6 01-13-2005 04:50 PM
Need advice on router mount samualt DIY-CNC Router Table Machines 3 11-08-2004 10:14 AM
Why do we spin the screws? Jcadwell CNCzone Club House 5 05-02-2004 11:33 PM
Z-Axis and Ball Screws samualt DIY-CNC Router Table Machines 15 01-10-2004 03:10 PM
