#13
| That's what I'm thinking but my controller box has a whopping 120mm fan that blows like a hurricane over the heatsinks of my drivers. I'll post a piccy of the box tomorrow and I'll try to moniter the temps of the three drivers whilst performing a long job. |
#14
| Well I've found the problem. The laptop that is running Mach3 was turning the moniter off after 25mins. This simple action was interupting the parallel port/Mach just long enough for the stepper to lose syncronisation and stall the axis. Once the axis was commanded to run again off it went. A simple and free fix! |
#16
| Why would the power saver cause a problem? I would think the mach3 engine would handle system interrupts with no issue.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
#17
| well to be honest, im not sure why, but i know that if i leave a program running that is processor cycle dependant, when the time comes to "power off monitors" it causes some glitching.... i would have to guess that its a combination of windows ediocyncries and processor usage... i'll try it sometime while watching my processor usage % and see if i can find anything... when i know that im going to be using something that is very time based and processor dependant i reset my screen savers and powersaver settings so that they dont activate... it might be a little hard on the old crt's to leave the images up for that long, but i would rather have to replace a monitor a little sooner (which i seem to do regularly anyway) rather than have something that i have left grinding away for hours get messed up...
__________________ Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino. |
#18
While Mach pretty much takes control of Windows to do it's thing, it doesn't have the ability to block other processes from interfering with what it's doing. On a very fast PC, it may not be a problem, but on slower PC's, it may not take much at all to interfere. Mach can be pretty CPU intensive, may and not have much headroom available for any other tasks.
#19
| I don't know how much control mach3 takes, or what the priority is as installed on your systems but I do know the XP 'background' processes run at a higher base priority than the applications. I've had a message queuing problem that was caused by a high priority system process jumping in over the top of the application and loosing sync. I'd suspect the power funtion is a system priority - i.e. base priority 'high' ? might account for the apparent problem. having said that Art is a smart guy and I'm sure he's covered this. To test it, in 2k and XP you can set the base priority from the task manager, taskmanager/processes right click the process (mach3?) and take the bottom option 'set priority' and set it to 'high' or 'realtime' I'm not a knowlegable user of Mach3 so this might be irrelevant but my install shows the priority as normal.. |
#20
| I know if your network card speed is set to "auto", it'll mess up Mach3. So will Quicktime if it's installed on your system.
#21
| Mach3 forum says the screen saver has to be turned off.
