I would like to use Ball Screws for my Z-Axis, mainly because of less backlash. However, unlike Acme Screws the Ball Screws will evidently let force on the nut turn the screw! (Backdriving). Question: So, if you mount a Ball Screw on the Z-Axis won't the weight of the router and other parts cause a continuous motion downwards because of gravity and try to turn the screw? Wouldn't your motor always be having to apply power upwards to counteract that? From Nook Industries: ----------------------------------------- BACKDRIVING Normally, ball screws are used to convert rotary motion into linear motion. Backdriving is the result of the load pushing axially on the screw or nut to create rotary motion. All ball screws, due to their high efficiency, will backdrive. The resulting torque is known as “backdriving torque” and is the torque required to hold a load in position. CAUTION - When using ball screws, applications should be analyzed to determine the necessity of a brake, especially when the possibility of injury may occur. |
| Ahhh - thats where the "holding force" on your stepper motor comes in! At least thats what I figure - thought I'd have that problem too and was going to add a pin to "set" the router in place - but haven't done that yet. Jim |
| Your stepper needs to be powerfull enough to lift the Z axis, so it will certainly be powerfull enough to hold it under the force of backdrive. The way to use smaller steppers is to counterbalance or use a spring, not by adding static friction as in acme thread. greetings, John |
| Your stepper needs to be powerfull enough to lift the Z axis, so it will certainly be powerfull enough to hold it under the force of backdrive. The way to use smaller steppers is to counterbalance or use a spring, not by adding static friction (as in acme thread). greetings, John Last edited by limbo; 12-22-2003 at 05:28 AM. |
| The "ballscrew lover's" solution is to use a motor with a brake. That way when the power is off, the brake is engaged. If you'll pay attention to a lot of commercial designs, they will use a precision acme screw on the Z to keep it from free wheeling downward when not powered. If they use a Ball screw, the motor will have a brake.
__________________ Nathan |
#10
| My Z axis on my router is powered with a .2 pitch ball screw and a servo is running it. I have the ratio of 2:1 and with the 3-1/4 HP Porter Cable router I just have enough mechanical advantage to hold the weight when the power is off of the servo motor.
__________________ Thanks Jeff Davis (HomeCNC) http://www.homecnc.info (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by HomeCNC; 12-31-2003 at 12:55 PM. |
#12
| Hi, One of the wonderful features of a vertical Z axis is that the weight of the spindle eliminates the backlash in the screw. If the detent torque of the motor isn't enough to prevent backdriving, I would use just enough spring to hold the axis in place, but I wouldn't balance it perfectly as that would introduce backlash back into the system. Steve |
| Ballscrew Basics | Swede | Linear and Rotary Motion | 94 | 09-06-2011 07:23 PM |
| Ball screws for Taig mills. Anyone? | Idle hands | Taig Mills & Lathes | 3 | 12-26-2009 05:55 PM |
| Revolutionary Linear Drive System | allanconway2 | Polls | 21 | 05-03-2009 09:27 PM |
| Ball Screws for my machine | CNC Brute | DIY-CNC Router Table Machines | 2 | 01-27-2004 04:11 PM |
| Ball Screws a good deal? | WadeConner | DIY-CNC Router Table Machines | 0 | 01-07-2004 10:10 PM |
