Old 12-19-2003, 10:08 PM
vertcnc is on a distinguished road
servo motors ?
I am in the beginning stages of building a 30" x 60" all aluminum gantry router to be used for wood and aluminum.
My original plans were to use steppers and Gecko's, but as I follow several of the projects it seems that servos are the way to go.
I have 5/8" 4 start ball screws with anti- backlash nuts. The motors are going to be connected to the screw via timming belt, So there is some room to adjust the ratio. I looking for speeds around 80-120 ipm with good resolution.
I found these motors and looking for some help. I am totally lost on the some of the labeling.
Reliance Electric Dc Motor
M# 0675
Back EMF Constant, Ke=68v/Krpm
Torque Constant, Kt=5.75 Lb-in/Amp
Nominal Speed Rating 1750 rpm
Nominal voltage Rating 120volts
De-Mag Current 53 Amps
500 line encoder
Tim
Old 12-19-2003, 10:27 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
Holy Cr*p!
120VDC! 53 AMPS! and 5.75 IN/LBS per AMP!!!!!
If the specs are correct,
You could roll a car over with one of thoes!
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 12-19-2003, 10:37 PM
DaSigntist's Avatar
DaSigntist is on a distinguished road
Wow . . .that would make a mill look like a dremal tool :-)
Regards,
Dasigntist
Never forget that only dead fish swim with the stream
Malcolm Muggeridge
Old 12-19-2003, 10:45 PM
They did seem a little stout for my application. I was looking at them mainly because of the nema 34 frame and I aready had some parts machined to mate to nema 34 steppers.
I keep looking for something a little smaller.
Old 12-19-2003, 10:53 PM
DaSigntist's Avatar
contact Dean @ Axxus
http://members.shaw.ca/axxus/
He can help you out within your budget.
Regards,
Dasigntist
Malcolm Muggeridge
Using surplus servo motors as spindle drive Swede Servo Motors and Drives 11 03-16-2008 09:05 AM
DC motors worthy of being a servo? WoodSnarfer Servo Motors and Drives 12 07-22-2006 02:25 AM
3 servo motors - What are the actual specs? Bloy2004 Servo Motors and Drives 10 06-10-2004 02:36 PM
General electric servo motors wanted Rich Monfo General Electronics Discussion 2 04-07-2004 04:05 PM
New Contest WIN SERVO MOTORS!!! CNCadmin CNCzone Club House 83 07-18-2003 03:16 AM
