Originally Posted by candle one last thing
i just read through your driver manual, and saw there is an optoisolator instead of diffrential drive - not bad thing i guess and schematics i've proven will still be valid
but - you may tide up all + (step dir, etc) to 5V and connect "-" pins as it would be plain driver |
Candle I am not sure that I understand these instructions.
Well per advise that I received here I decided to eventually use my 5630 drivers and have purchased another Pacifis S. 5630 Stepper Driver today on Ebay (Hope it works) and pretty much blew my cheaper than cheap budget. All of the parts I have gathered thus far were all free. At least now I have a matched set for X and Y axis. Z will have to be something else for now.
I was able to sample five of the LMD18245 from National Semiconductor, which are the expensive part of the Picstep Driver boards so I guess I will build them for my other axis's Z and beyond.
So now I need to decide on a good controller that will hopefully drive the Picstep and the 5630's, any ideas? By the way, incase nobody noticed these motors that I have are all Bipolar Hybrids so as I understand it they can be very good motors!
Chuck, thanks for the info, I work with elecro-mechanical things by proffession so I hope I can manage this build. I think that you make a good point that there are some good things out there to use to keep costs down. I do have some Linear bearings and .5" dia. shafts about 20" long that I think will be great for the Z axis, and some long approx. 4' solid 1.5" round bar that I think will work for the X and Y. For the X and Y I will have to create some sort of linear bearing assembly to run on these shafts. For the bulk of the body I will start with Plywood (I allready have a bunch in the garage), but hope to use the CNC to eventually upgrade itself to something more robust it the future possibly Alum. or even steal (Has anybody made there own Laser cutter or waterjet cutter yet?).
Keep the Ideas coming I apreciate all of it, and I hope to start a new thread with build pictures and ideas some day soon.
