  #73   Ban this user!
Old 02-04-2007, 07:35 AM
truman is on a distinguished road
no I havn't replaced it yet I am working on the small pieces right now that was all I cut so far but I will be cutting more soon and I will post everything as I go
Rob
  #74   Ban this user!
Old 02-04-2007, 05:24 PM
well I made some modifications and cut my bearing blocks in mdf they turned out perfect
Rob
  #75   Ban this user!
Old 02-06-2007, 02:41 PM
mhiggins is on a distinguished road
Originally Posted by truman View Post
well here is the first alluminum part I cut on my machine I was very happy with it it was only out about 2thou. I screwed up when I made the toolpath by selecting inside instead of outside edge for the path to cut it out. I cut it at 30ipm and took 0.030" passes very light but well worth the wait if you are wondering what it is it is a bearing block hope to upgrade all of the hdpe. oh ya I used a two flute upcut carbide endmill at 16000 rpm.
Did you use any kind of cutting fluid when you machined these?
  #76   Ban this user!
Old 02-06-2007, 03:24 PM
those ones are just mdf but for the alluminum I squirted a little wd40 as it cut works well.
Rob
