#49
| Hi All, I want to share the picture of embroidery artwork RENE has done on his ordinary sewing machine using my Software... He did a great job on it... Rene.. You have to do following things to get positive results... 1- Tighten the clothe very well on the Hoop. 2- The white thread on the bobbin emerging in picture shows that Bobbin thread needs more tention... 3- You should apply some embroider paper behind the cloth..This will give drastic improvement in embroidery.. I am adding RENE work here... I hope you all will like what we can do.. ![]() ![]() Further details can be seen in following thread... http://www.cnczone.com/forums/showth...=57404&page=23
__________________ http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/ http://my-diysolarwind.blogspot.com/ Last edited by Khalid; 04-06-2010 at 08:49 AM. |
#50
I saw something like what you are describing at a quilting show one time, it was called MAX-THROAT. It worked with the PCQ system (stands for PC Quilter) It worked quite well. I want to do the same thing with my CNC Quilter, I just haven't had the time to sit down and draw up the plans yet. I am thinking that the scale of the Y axis will have to be the same as the scale for the rollers, so that it moves the quilt the same amount of distance as it would in the quilting phase. it would be pretty easy to program the roller commands into Gcode as A-axis, B-axis, etc. and insert them into a spot in the code that will make the movement at the right time. It's all in the timing! I was also considering using a belt wrapped around the rollers, but I can see difficulties in the future with that design. I am thinking of using some 1 1/4 inch belt pulleys on each of the rollers, with a milled shaft into the roller to hold it in place. I just need to find someone that can mill the shafts for me. I need to make a drawing of the shafts and pulleys to cement the idea. Do you have any paper plans on your project? if so, I would love to see them. Larry
__________________ Larry |
#51
How is your project coming along, did you get the issue with the speed taken care of. Haven't heard from you in a while, so I thought i would ask.
#52
| Hi Larry Sorry my late answer .. Iam very busy in work. I paused embroidery machine building, but I get some progress in A axis work at high speed Look my xml file, and test... Later I will make a more long message... Regards Rene |
#54
Hey Deviant, I have an answer for you! First, buy open ended toothed belt and a pulley gear for the motor shaft that you have. Second, use coreldraw x4 and get a copy of DXFtool for the Corel. DXFtool is a macro that will convert your drawings to a DXF file. Once you have a dxf file, run it though lazyCAM or your favorite CAM program and convert it to a gCode program file. Then use Mach3 to run the system (motors, controller, etc) and it will run. Chances are that you may have to adjust the scale by clicking on the axis scale in Mach3, and setting it at maybe .05 or so to get the right size. You may even have to set it smaller. It all depends on the size of the file that you convert. Let me know if you have anymore questions.
#56
| Hi, Sorry my ignorance, I don't know nothing about quilting I was looking some machines an videos, and reading here I think that is possible to do quilting like if we are doing embroidery, without use a cruise controller or stitch regulator. I we have a desing for quilt, and we can make a Tajima (dst) file using this design, then we can generate a Gcode using Khalid Embroidery G code generator. Wilcom can import graphic files and conver it in embroidery file for example. using Sophiesew(free) or Willcom. In this case, G code will contains the properties of the stitches and isn't needed the use a stitch regulator or a cruise controller. Software will do all job. X and Y axis will be for move the carriage and sewing machine using belts or rack and pinion in X axis and a multiple start acme threated bar 1/2" 5TPI for move sewing machine Needle operacion can be done using A axis, some regulation of needle speed operacion can be done using Rotation Diameters in Settings Page, in this way needle speed could be regulated in long stitches. I have tested system and some g code and seems to be good. Stitches per minute is about 480-500 , I don't know if this is fast or slow for quilting. I have some idea of build a machine similar a quilter, but not for quilt, only for embroider work in fabrics for curtains, etc. I think to use this proccess. Thanks for your comments Rene PD-Sorry my bad english |
#57
How's it coming on the takeup roller automation? I am working on my design now, I plan to mount it on clear acrylic plexiglas cut to fit both ends of the table with a linear rail and carriage on each end with two gears to guide the rail ends true and square. My only issue at this time is controlling the motor which is to be mounted on one end with a spool that will contain 50 lb test stainless steel wire to act as the pulley. Now, I was thinking of using a small spring motor to keep tension on the roller/fabric, and also back up the roller when the motor releases tension. I was thinking about using one of the extra motor ports on my Rockcliff controller card to feed command to the motors, but I would also like to have control to manually release tension or tighten it from the keyboard. That's the easy part, just a matter of assigning the proper keystrokes. I would love to see what you have done, do you have any photos, diagrams etc?
