If I use 1/2" lead screw and my motors have 1/4" shaft - Where can I get couplings to allow my motor fit to end of lead screw? Or is that not possible? Links would be helpful - thanks Many thanks!@
__________________ Please check out my CNC blog http://cncinside.com |
| you can always get one 1/2" coupler, and one 1/4 coupler with a lovejoy connector from mcmaster carr, that always works. But if you are using acme thread, the 1/2 coupler will not fit great onto the threads. Dumpster's bad ass couplers are threaded acme on one side and 1/4 on the other. he has several thread options to choose from. Got mine today and they fit great. That way I don't have to machine down the acme thread to fit a 1/4 coupler. Plus they are pretty cheap too. |
| What Dumpster has done is made a split-coupling that clamps on the 1/2-10 acme thread, and also has a 1/4" dia hole to clamp on the motor shaft. This is great for those who are unable to have the ends of their leadscrews turned in a lathe! However, I would recommend drilling a small cross-hole and pressing a split roll pin through the shaft and coupling to ensure it does not slip or come loose! |
| Thanks - they look perfect. Is this a good price for lead screw? EBay Auction # 230018828843 http://cgi.ebay.com/48-1-2-10-ACME-L...QQcmdZViewItem
#10
| Yes, thats my friends eBay page! He is making all my stuff now, I could not keep up with the demand from ebay! By the way, this screw has turned ends, and you will need a coupling to go from 1/4 to 1/4 It will also require bearing blocks for the ends! Eric |
