Old 08-16-2006, 06:51 PM
Bill Davis is on a distinguished road
Using different tpi lead screw for x y
Using Mach3.
Using lead screw 4 tpi for the Y axis and using something other than 4 tpi, say 5 or 8 tpi lead screw for the x axis. Will this cause me problems in setting up the axis drive calculations. Reason for questions is I have a lead screw 4 tpi and been and shoping around for another 4 tpi with not much luck. I have located a 5 tpi lead screw at a reasonable price. But I need to know if this will work for me.
thanks
bill davis
Old 08-16-2006, 07:06 PM
Kipper's Avatar
Kipper is on a distinguished road
Dont see why it should cause problems in Mach software. I keep changing it's parameters and it hasnt baulked yet. hth
Keith
