I found this at QuickRout tool Sears. (I think its the one ger21 was talking about in another thread) It says it fits a Craftsman router. It looks like it mounts to a 1/2" shaft on the router with a a 1/2" collet. The bit side has a taper shaped quick connect that the adapters snap into. The 1/4" router bits are held by the adapters with two set screws. I don't know if it will fit a Porter Cable. Does anyone know what size shaft is on the Porter Cable router? $29.99 Sears item #00926691000 Mfr. model #26691 http://www.sears.com/sr/javasr/produ...id=00926691000 Bill |
| It appears that with this tool, one could have preprogramed tool lengths saved in the software? Is this correct?
__________________ Shoptask rebuild: http://www.cnczone.com/forums/showthread.php?t=2139 Home built gantry router: http://www.cnczone.com/forums/showthread.php?t=5049 |
| "It appears that with this tool, one could have preprogramed tool lengths saved in the software? Is this correct?" Yes. (I don't know how accurate they relocate each time) You can buy extra adapters. I think it was $10 for 2 or 3 of them. This would be a big time saver if I can use them on my router. Just need to find out if it fits. Bill. |
| They have one for a porter cable, but I don't have the part # right now. Iwas able to find it on the sears website, though. Gerry
| Good find if they index. I supose they only hold 1/2 and 1/4. My custom Porter Cable holders are still working great!
__________________ Thanks Jeff Davis (HomeCNC) http://www.homecnc.info (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Porter Cable version - not sure if they sell a full PC set. I'll have to stop in the store and take a look, because the website kinda sucks for searching for these things. http://www.sears.com/sr/javasr/produ...id=00926696000 Gerry
| Picked up a RotoZip "CH01 adapter" at Home Depot to fit Dremel bits into my Porter-Cable Laminate Trimmer thats running on a Harbor Freight Router speed controler. (Now thats a search engine's nightmare )But seriously it fit the bill - how to get 1/8 bits into the 1/4 inch chuck. Works good and cheap enough to buy a second and drill out to 3/32 for other bits. (less than 6 bucks) Jim |
Im interested to find out also. It does seem like a pretty good idea |
#11
... the Eliminator Chuck, (originally designed specifically for the Porter Cable routers and now available for other brands), on several of my router tables, Leagacy Mill, etc. Works very well! You can find them for $49-$59 and toolchanges are 10 seconds with the one hex screw. Also, having seen Jeff Davis's (HomeCNC) custom collets and how he has each tool set in his tool library... it's tough to beat! |
#12
| I used them several times and they work OK. Cut good and easy to change tools. The length stays set. It does set up a vibration that I did not like. If I have a toolpath that runs a long time, I don't like to use them for extended time because the vibration seems like it might be hard on my router. I don't know if they can be balanced. Something that might be worth trying. Has anyone else used them? maybe its just mine that are out of balance? Bill |
| Quick built router | CNC Darren | DIY-CNC Router Table Machines | 10 | 06-05-2005 09:09 PM |
| Router bit feed rates. | ynneb | DIY-CNC Router Table Machines | 3 | 05-28-2004 12:54 PM |
| Multiple Bit Hobby CNC Router, Possible? | Sanghera | DIY-CNC Router Table Machines | 27 | 04-17-2004 01:20 AM |
| Quick change head design | kdoney | DIY-CNC Router Table Machines | 1 | 07-05-2003 12:57 PM |
| Quick change bit holder | Laff Riot | Machine Problems, Solutions , Wireless DNC, serial port | 5 | 04-17-2003 12:48 AM |
