Old 08-13-2006, 02:27 PM
KrashKing405 is on a distinguished road
Stepper ICs
Tried asking this in the open source controler section, never got an answer, but: Anyone used the Texas Instruments UC3770AN chip, what about the A3959SBT from Allegro?
Old 08-13-2006, 06:19 PM
pminmo's Avatar
pminmo is on a distinguished road
I've got a A3959 design in works. Looks to be a great alternative to the expensive LMD18245's!
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 08-13-2006, 08:15 PM
Do I need 1 chip per axis, or will 1 control all 3?
Old 08-13-2006, 10:48 PM
pminmo's Avatar
you need two chips per two phase stepper. It will be a one axis board, same as my others.
Old 08-14-2006, 05:59 PM
I got 6, so I should be good then.
Old 12-06-2006, 07:30 PM
Any progress on the A3959 boards?
Old 12-06-2006, 07:49 PM
pminmo's Avatar
Not really, when Allegro released the A3986, all my attention went to it. SInce the A3986 allows a higher current implementaion at probably less cost, It's more likely a better solution.
Old 12-06-2006, 09:25 PM
any developments on that?
