Old 12-12-2003, 11:31 AM
Cold Fusion is on a distinguished road
Single vs Dual Lead Screws
I was thinking about using duals like rmtucker but need some input. It's for a 24x24 table.
Proud owner of a Series II Bridgeport.
Old 12-12-2003, 07:44 PM
InventIt is on a distinguished road
I'm having problems with mine. I think one leadscrew/one motor per axis is the way to go.
Old 12-12-2003, 07:54 PM
balsaman's Avatar
balsaman is on a distinguished road
I have heard if you go dual screws you should do it with one motor, and a belt.
Eric
I wish it wouldn't crash.
Old 12-12-2003, 10:05 PM
steveald is on a distinguished road
Hi Eric,
I agree with the one motor approach. If you use twice the power in one motor, you can probably use the same power supply, and only one driver, cable etc... and it's mechanically sync'ed, so any lost steps or backlash in the belts wouldn't affect squareness, only position. Any reduction in the motor to screw speed could be done with the one belt by changing the pulleys on the screws or the motor pulley. I think it's a lot simpler and less prone to problems than trying to sync 2 motors electrically.
My 2 cents,
Steve
Old 12-14-2003, 01:26 AM
DDM DDM is offline
DDM is on a distinguished road
How wide of a table would you guys say is the limit before you would need two lead screws. I'm thinking something along the lines of 36" or so. What are some other factors for wanting a dual lead screw setup?
Old 03-08-2009, 05:26 PM
shawnc515 is on a distinguished road
Talking
the router at my school has only one with the screw fixed and the nut turning, and that has a cuting area of just over 4' x 8'.
EDIT: did not see this was and old post
how do i choose the right lead screws? dansal DIY-CNC Router Table Machines 32 04-06-2009 04:48 AM
Question obout acme threaded rod (lead screws) Hack Mechanical Calculations/Engineering Design 1 04-02-2005 01:12 PM
Duel Lead Screws bb99 Mechanical Calculations/Engineering Design 6 03-18-2005 03:51 PM
Twin lead Screws Joe_CNC Employment Opportunity 3 04-09-2004 01:18 PM
Where to purchase lead screws? sixpence DIY-CNC Router Table Machines 2 01-25-2004 02:18 PM
