Old 12-11-2003, 04:56 PM
tjstraz's Avatar
tjstraz is on a distinguished road
Spindle?
I'm starting to design a cnc router and am wondering what people are using for spindles?
Utimately I want to be able to control spindle speed through g-code. Is there anyone implementing this? If so, I'd be interested in hearing how you are setup.
Thanks,
Tim
Old 12-11-2003, 07:59 PM
balsaman's Avatar
balsaman is on a distinguished road
I don't do it but am considering coupling a floppy stepper to the speed pot of my router speed control. Then calling that axis "S". when the gcode calls for s10,000, then that axis (stepper) will go to a predetermined location which maybe will be close to 10,000 rpm.
I guess it's an undocumented feature in Turbocnc......
Eric
I wish it wouldn't crash.
Old 12-11-2003, 08:40 PM
DDM DDM is offline
DDM is on a distinguished road
speaking of spindle speed control is there a way with the xylotex controller to connect it to you're spindle supply via relay or something so that you can Call a M03 and turn on the spindle with the program vs. doing it all manually. I just thought it would be a trick feature to have on the machine I'm planning on building in the near future. As far as having speed control what determines the speed at which the spindle turns at, Volts? I'm not sure on a lot of this stuff but I'm learning as I go along.
Old 12-11-2003, 08:43 PM
balsaman's Avatar
I think the xylotex has an output of two.
For a router, it's volts generally.
Eric
Old 12-14-2003, 04:26 PM
Carver is on a distinguished road
I don't know about exporting control for a Portercable type router but I suspect it could be done. With a high frequency spindle ( i.e, Columbo ) it is a simple process of getting the command to the spindle as part of your g-code. The same command with a negative number reverses spindle direction also.
It is indespensible if you want to match your speed to you cuts without running separate posts for the same tool.
Best of luck,
Phill Pittman
www.masterwerkes.com
digicarve@verizon.net
Phill Pittman
phill@masterwerkes.com
Sherline spindle to 30k RPM -- am I crazy? nicad General Metal Working Machines 21 11-17-2010 03:57 PM
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 08:01 PM
Mill spindle repair? kong General Metal Working Machines 6 04-02-2005 01:01 PM
Gilman box spindle pics Swede Benchtop Machines 5 03-30-2005 10:41 AM
2.2KW Allen Brad. Spindle motor? GalaticDan Servo Motors and Drives 2 02-02-2005 12:46 PM
