Old 12-10-2003, 12:45 PM
Cold Fusion is on a distinguished road
Home-made or CheapCnc (Noobie)
Hello, I'm new in the cnc world and I have a few questions.
1: Can a cheaper cnc router like the ones made by Cheapcnc cut 1/4 Lexan or 1/8 Carbon Fiber? I do alot of custom work by hand but would like to start using cnc for it.
2: Can these machines do drilling as well?
3: Is it worth it to just buy the parts myself and make one or would that be too hard for a beginner? If so, how much will it cost?
Here is a picture of some of the stuff we do in Lexan.
The chassis are about 14"x6"
Btw, I had a typo in my user name. Could someone change it to Cold Fusion?
Proud owner of a Series II Bridgeport.
Old 12-10-2003, 01:01 PM
HomeCNC's Avatar
HomeCNC is on a distinguished road
It all depends on how fast you want to cut your parts. A very weak machine can cut what you ask, you just would need to take very shallow cuts and slow speeds.
2: Can there machines do drilling as well?
Sure. The main problem would be the RPM of the router and finding a drill chuck that will handle the high speed. I tryed drilling with my vara-speed router on 10,000 RPM. It worked but shook a bit.
It is not hard to build one. I see you can run a CAD station. You need to make the choice between router or mill. The part you have shown could be made on my converted Mill/Drill (see my website). Also I just wanted to say that using a router or mill, you will not be able to cut square corners on pockets like you have drawn. I would say to not be scared to build one or to convert a mill/drill. You will have all the help you need from us here.
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 12-10-2003, 01:04 PM
I want a router style, not mill. The mill just has too small of a table. I'm looking for something roughly 24x17 or larger.
Old 12-10-2003, 01:07 PM
Btw, these parts go on a Traxxas Rustler Rc truck.
Old 12-10-2003, 02:27 PM
ECRC is on a distinguished road
I've dropped .21 motors in a few of them, they get real fun after that!!!
You don't need a real srtong machine to cut CF if you slow it down a bit.
Doug
Old 12-10-2003, 03:01 PM
I'm an electric guy. I've got a brushless Supermaxx right now in addition to the brushless electric Team Rustler.
How long do you think it would take to cut a chassis out of Carbon Fiber or Lexan with a 1.5k homemade one.
Old 12-10-2003, 03:18 PM
I'm no expert with the different machines, but I would say that my machine could cut it in 2-3 min. You can see my machine in the liberty sect.
Doug
Old 12-10-2003, 03:20 PM
That would be great for us. It normally takes me 2 hours to finish a custom chassis job...
Old 12-10-2003, 04:32 PM
tsalaf is on a distinguished road
Cold,
If you can make that chassis with hand tools, you can build a CNC router.
You will fall asleep waiting for a cheap machine to cut your parts at 8 in/min. and your plastic will turn to goo with a router moving that slowly.
I think you would be better off spending the $1500 on better components and your own labour to get a production quality machine that you will still be happy with after a week. As for drilling, if the hole has a diameter that is smaller than the diameter of the cutter, you can route the hole without the danger of using a drill chuck in a router.
Steve
Old 12-10-2003, 04:45 PM
yukonho is on a distinguished road
Just to let you know, I am building a CNC router now, it is my first one. So far it has cost me about $300 including steppers and driverboard. I am using a dremel tool as spindle, so if you went with something bigger, it would cost you more. I estimate about another 50 to 100 dollars before I am up and running.
So, if you are looking to do it as inexpensively as possible, make one yourself. It is really not difficult, most hobbyists could do it. Also, if you are willing to spend more money than I did, you can have an awesome router for your $1500.
co
  #11   Ban this user!
Old 12-10-2003, 04:46 PM
Ok, I will go with a homemade one. I've been reading alot on these forums to figure out how one works and how to build one, but I think I will need some kind of guide to do it. So you really think I can make a good one under $1500? Right now I pay about $400 per cnc order I make. This should pay off fairly quickly.
  #12   Ban this user!
Old 12-10-2003, 04:47 PM
I use a dremel everyday and I don't think it has the power for what I want. Some kind of bigger router would be great.
New home made MadVac CNC router oneyaker DIY-CNC Router Table Machines 20 02-05-2011 06:37 AM
Any home made cnc laser's out there? CNCadmin Laser Engraving & Cutting Machines 3 04-08-2009 06:46 PM
First tool for the tiny lathe (home made) pics Stevie General Metal Working Machines 5 05-02-2004 11:24 AM
Home made CNC mill (and some products made by it) gcamlibel DIY-CNC Router Table Machines 23 04-05-2004 06:54 PM
home made CNC wire cutter and router geesville DIY-CNC Router Table Machines 5 02-05-2004 09:24 PM
