#62
These photos show the vacuum manifold completed. Now I just need to seal the ends of the 6x2 aluminum tubes, and perforate the tops (done last using the router), connect the manifold to the intake of a regenerative blower, and I'll have a vacuum hold-down table. Steve |
#63
| is there anyway you could maybe contact me and give me some info as to cost and design? ive been looking for nearly 2 years now and i love your router, best looking one ive seen anywhere, and the size seems perfect for my small condo, please let me know thanks s_bedow@comcast.net s_Bedow@hotmail.com |
#65
#67
| If you look at the above pic on the right in full size you can see protrusions in the tubes. My guess is that they are bolted only on the ends. ???
__________________ Mark -------------------------- Check Out My Build-Log(s): http://cnczone.com/forums/showthread.php?t=4716 CNC Router Version 1 [====================] 100% http://cnczone.com/forums/showthread.php?t=39294 CNC Router Version 2 [=|-----------------------] 5% |
#68
| Hi, I've been away for a while. I attached one piece of t-slot to one 6x2 tube, using #10 self tapping sm screws, repeated the process 7 times, and then mounted the 8 assemblies to the frame. One tube had 2 pieces of t-slot attached. Each piece of t-slot is only attached to one tube. I had a base built out of steel tube and attached the gantry. I was surprised at how well it slides on the gantry, I thought I would be tweaking and shimming for days, but it worked first try. There is still lots of work to be done, but it's getting closer. SA |
#69
| That is one impressive machine!! Good looking smaller one in the background too. What type of work are you planning for the big machine? With the low-clearance, I am guessing sign work?
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452 |
| Home built barfeeder | Fudd | General Metal Working Machines | 2 | 01-28-2008 08:50 AM |
| Quick built router | CNC Darren | DIY-CNC Router Table Machines | 10 | 06-05-2005 08:09 PM |
| purchase or building a home cnc router. | s_bedow | DIY-CNC Router Table Machines | 9 | 03-19-2005 12:22 AM |
| Home Built Router/Drag Diamond Engraver | DaSigntist | DIY-CNC Router Table Machines | 49 | 01-24-2005 01:02 AM |
| 5 Axis Rotery Head Home Cnc Router | mace | DIY-CNC Router Table Machines | 22 | 09-18-2003 11:29 AM |
