Old 07-29-2006, 07:33 AM
xyz100 is on a distinguished road
home switch for rotational axis
How do I implement a home switch for a rotational axis (table)? How do they do it for 5-axis machines?
Old 07-31-2006, 01:14 PM
teebee is on a distinguished road
just add a SHCS screw to the rotating table, that will hit a schwitch when turning...
you can home then by running the table to the schwitch (always in the same direction) and then, when you got the signal, slowly run away from it again (reverse direction). The moment when you lose the signal again is "home (sweet home)"
