  #25   Ban this user!
Old 12-16-2003, 10:27 AM
BeerFizz is on a distinguished road
Better detail of the right hand side of the chart...
Old 12-16-2003, 01:32 PM
ger21's Avatar
It looks like about 30 ipm to me for the simple (A), about 120 ipm for fixed (D).
  #27   Ban this user!
Old 12-16-2003, 04:51 PM
Perhaps I wasn't clear or perhaps the document isn't clear, but I was thinking of “Simple” as representing one bearing at each end, and “fixed” as representing a double bearing at each end. This would then correspond to line “B” and line “C’ on the chart, respectively.
Old 12-16-2003, 09:12 PM
ger21's Avatar
Looks like you're about right, then.
  #29   Ban this user!
Old 03-29-2006, 11:29 AM
martinw is on a distinguished road
[QUOTE=ger21]It looks like about 30 ipm to me for the simple (A), about 120 ipm for fixed (D).
Gerry[/QUOTE
Dear Gerry,
This may be a daft idea, but has anybody thought of spacing the two halves of their anti-backlash nut several inches apart? If you did, the AB assembly itself would become fixed, I think, and would greatly lessen any tendency of the leadscrew to whip because the two halves of the nut would keep the screw in line.
Regards
Martin
mounting flexible couplings to 17mm shaft cowanrg General Metalwork Discussion 14 04-11-2005 12:40 AM
Where can I find supported shaft? Cold Fusion DIY-CNC Router Table Machines 10 12-18-2004 09:49 PM
Thompson Shaft and bearings flex help? foamcutter DIY-CNC Router Table Machines 9 04-24-2004 04:24 PM
My huge shaft! kong DIY-CNC Router Table Machines 4 08-29-2003 12:54 PM
Drilling hardened steel shaft Zephrant General Metal Working Machines 12 06-13-2003 03:42 PM
