Old 07-25-2006, 07:09 PM
xyz100 is on a distinguished road
What is this? Linear bearing?
Does anyone know what this is? And how it is called. And where I can buy these?
Old 07-25-2006, 08:10 PM
Madclicker is on a distinguished road
Looks like a 2 bolt flange bearing.
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Old 07-26-2006, 06:07 AM
This particular one has 5/16 ID. Do you know where I could buy these in other sizes (bigger)? I like the design. It has two inserts. One in the front, another in back. The middle area is designed to hold the grease.
I checked internet stores. So far I have seen single piece plactic pieces only.
Old 07-26-2006, 12:55 PM
Moderator
JerryFlyGuy is on a distinguished road
Search for PVC,UHMW or Plastic bearings? I've not seen ones like that before. OR.. you could just get a standard 2 hole, flange mnt, Pillow Block bearing.. they come in ALL sizes.. and can be aquired from just about anywhere..
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
