Old 07-17-2006, 10:11 AM
villas is on a distinguished road
What type of CNC do this work ???
All types of DiY CNC do this in acrilic? (the image is in alu- dimensions in mm)
Anyone can make this for me? how much?
PS.: dimensions in mm
Old 07-17-2006, 11:55 AM
chronon1's Avatar
chronon1 is on a distinguished road
um.. looks like a vice jaw or grabber , tightner type thing of sorts...
i thought acrylic was a type of paint ! i think its also a plastic engineering material ( not unlike PVC, Delrin or ABC ? )
I think it's missing the dimension on distance to arck on top (before the 15 deg radius curve)
Old 07-17-2006, 01:03 PM
widgitmaster's Avatar
Gold Member
widgitmaster is on a distinguished road
Why CNC?
What quantity?
Acrylic (plexiglass) is free machining, and pours well into molds too!
So why do it with expensive machining?
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
Old 07-17-2006, 01:16 PM
I need in solid acrilic for polish later. The dimensions is all there.
Old 07-17-2006, 01:23 PM
Originally Posted by widgitmaster
Why CNC?
What quantity?
I think (maybe wrong) it is very simple to make in a hobby CNC ... i need in this case 1 peace only and if i have a simple and litle Mill it is easy but i dont have one.
Acrylic is for polish later. It is a matrix for make a model in composite.
Sory about my english !
Old 07-17-2006, 01:46 PM
Gold Member
InspirationTool is on a distinguished road
Villas, that part would be a pain to make... you'd have to do several setups because you can't cut the whole part coming from one direction. I don't even know if it possible to get those sharp inside corners on a mill.
You will need to redesign it, or pay alot of money, IMO.
-Jeff
Old 07-17-2006, 01:57 PM
greybeard's Avatar
greybeard is on a distinguished road
villas - you say you want to finish with a "copy" from which to make composite copies.
I assume you have the aluminium original that is in the photo.
If this is so, and the dimensions are as you have drawn(or are they different?), I would resurface the aluminium with any filler/ paint, whatever, to cover up any blemishes. Then make a mould using silicone rubber, and cast a copy in acrylic. Polish that, then you have what you need for the final mould.
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
Old 07-17-2006, 02:01 PM
Gold Member
What John said
-Jeff
Old 07-17-2006, 08:08 PM
Gold Member
Cool
You are correct, there is a missing dimension in the side view, the line where the horizontal hole starts.
Eric
Old 07-18-2006, 06:57 AM
Eric
absolutely correct ... sory .. (the 11,3 mm ) there it is ... edited all dimensions include the R 2 degrees .. i forgot that.
  #11   Ban this user!
Old 07-18-2006, 07:02 AM
John
The changes i need dont permit a resurface of this aluminium piece. I need to make another one with diferent dimensions. I have all material for copy in composite with a silicon rubber (all the process is for it).
  #12   Ban this user!
Old 07-18-2006, 07:11 AM
-Jeff
Jeff
I make that piece in a mill but it cost me about U$50,00 and it is a lot for me.
The work is for 2 or 3 hours in a good mill in aluminium and i redesign de dimensions ... i forgot the R 2 degrees inside hole.
This is the first piece in acrylic (the aluminium is the version 2)
