im running my motors with gecko drivers ,the motors are 4 amp 3v , i have found that they got fairly warm when i ran them at 28v ,now i have connected a second supply in series and i m running at 56v and the motors get very hot after a while , i can touch them but i can t wrap my hand around them for long (hot) ,,everything is correct proper resistors and wiring , i am nearly 20 times the voltage so i can understand the heat steppers get hot but what is roughly the failing temp of these things |
| Hi, My stepper are rated to 80 degrees C; running them at 50V and 4.6A which is near their max. They get so hot that I cannot touch them for more than a few seconds, but when I measured the temperature they were only 76 degrees C. Hope this helps, John |
| Be kinda carefull if your steppers use rare earth magnets (maybe even if they use regular magnets too?). Take a scrap rare earth magnet and heat it up in the oven, at maybe 250 F it will demagnitize (might be higher than that for some magnets, or maybe the one I tried was poor ) |
| have you read mariss' white paper on stepper motors? Anything past about 20x the rated voltage just becomes heat. My experience is past 10x and the heat rises alot, and not linearly. why did you go from 28v to 56v? Was there performance issues at 28V? erie |
| If a motor is rated 100 C that sa hot motor. ( 212f ). If the motor has a name plate it should give all kinds of info about it's use. It will tell you how many times you can start and stop or what kind of insulation it has. Servo's are different because most rely on shaft rotation motors require rotation to keep air moving around them but servo's may hold position without moving ...nothing prevents you from cooling a motor with an external fan ..it is common for some manufactures to include an external fan located at the motors rear . |
thanks for the replies bigger better or crash and burn |
#10
| Not sure about your motor, but most motors are rated at maximum winding temperature "hot spot" - not surface temperature. If you approach the rated temperature on the motor case - you are vastly over the limit. |
