  #85   Ban this user!
Old 09-25-2004, 07:18 PM
Txfatboy is on a distinguished road
Great Machine. I would like to see a final picture. Also what software are you using?
  #86   Ban this user!
Old 01-04-2009, 05:21 PM
calaber40 is on a distinguished road
Angry two screw scare
hi guys im new to this cnc stuff and a quik learner when it comes to building things. im well into my build and am at the point of installing my 2 screws under the table for my gantry. what worries me now is what i have read in regards to 2 stepper motors running each screw and having them go out of sink ,so to speak, and all hell brake loose. i was first going to go the one stepper motor in the middle with 2 screws and a timing belt .motion tech . the supplier of my rails and electronics advised that i would get to much backlash, this way.is this true ,or does he want to make more money off of me.lol.my machine is about 48''x60'' so the belt will be spanning about 20 to 24'' across. i am looking to cut foam , mdf . and useing a trim router . if anyone have any imput on this area of a biuld , it would be very appreciated.you can see my cnc in the photo gallery.[ these are the pros and cons i ponder]
  #87   Ban this user!
Old 01-04-2009, 07:04 PM
CarveOne is on a distinguished road
I have similar concerns for my second build which will use dual steppers on the x axis. The Solsylva belt drive on my first build can slip if one lead screw binds and the gantry gets out of square. The dual stepper direct drive that I will use on my next build can have more serious problems if one side binds up while jogging at much faster speeds than I have available now. Just have to make sure everything stays in alignment and running freely.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
  #88   Ban this user!
Old 01-04-2009, 10:09 PM
hi inventit. i like the way you set up your pully system . is there a reason you went with three belts instead of one with a tensioner .and does the size of the pullies make for more or less backlash. eg. bigger pully more contact on the belt ,so more teeth can bite,that sort of thing.if thats the case ,does it effect the tork on the stepper motor if there bigger.and providing there all the same size.is it possible to get a more illistrated pic of the centre pully setup .really torn up at this point of my build . i dont want to spend 350.00 bones for another stepper , driver , and power supply ,only to find out it will work just as well with a belt system.plus i dont want to ever exsperience my cnc machine rip itself apart if one motor goes Awall lol.ps great build must have read it a dosen times thx .gino.
  #89   Ban this user!
Old 01-04-2009, 10:20 PM
do you think adding a extra motor driver and power supply is cheaper than a pully set .if its less than 350.00 i think all go with the pully set not just for cost but also if something goes wrong it wont tear my cnc all to hell.and exercisums are not cheap either.as a new be at this they say sh??t happins,and it will.any good place to pick up some pullies and belts at a good price?.
Collapsable router table? samualt DIY-CNC Router Table Machines 3 03-27-2007 09:02 PM
Anyone using xylotex stepper kit for a cnc plasma or router table? muleworks Xylotex 2 03-10-2006 07:52 AM
Need help finalizing plan for CNC Plasma table David Bord CNC Plasma and Waterjet Machines 6 05-25-2005 07:16 PM
CNC Plasma table plans krazycnc CNC Plasma and Waterjet Machines 4 05-05-2005 09:51 PM
My plasma table design m_c CNC Plasma and Waterjet Machines 16 07-24-2004 01:01 PM
