Old 12-01-2003, 07:28 AM
kong is on a distinguished road
Squaring the axes
Just wondering what you guys have done to ensure squareness between the x and y axis? I know "cut and measure" can be used, but there must be a more accurate way?
Old 12-01-2003, 11:26 AM
balsaman's Avatar
balsaman is on a distinguished road
I put a big square along the x, clamped it, then lined my spindle with a dowel in the collet up to it. Jogged to the other side, adjusted, jogged back, adjusted, etc. etc. until it was close enough for the parts I gotta make. I don't have a machinist's square so I used a carpenters square. It's probably out a few thou.
Eric
I wish it wouldn't crash.
Old 12-01-2003, 12:11 PM
turmite is on a distinguished road
Hey Eric are you saying we woodworkers are not sq?? That's the best news I've had in yrs.
Kong when I first set up my Digital Tool router I used the cut and measure method but I kept the first cuts within the max of my dial calipers, 8". I would cut and then measure etc and etc. After getting it as square as I could I cut a square as large as my machine would cut. 72" and checked it with a tape. Since that inital setup I have never had to resquare. Half of my parts are within the 8" square with the dial caliper so I know they are probably as close as I can get the machine. I just wish I had a set of 72" dial calipers.
turmite
No greater love can a man have than this, that he give his life for a friend.
Old 12-01-2003, 12:31 PM
barbwirebi is on a distinguished road
Good question
On a larger (72" Y) table this would probably be important.
How about the old 3'x 4' x 5' triangle method using a taut masons string and a tape measure?
Then use a dowel or pointer in the spindle to jog up & down the Y to check it against the string
The thought is to make the triangle as large as possible to gain better accuracy for perpi.
You can double the 3' x 4' x 5' to 6' x 8' 10' to become more accurate
Barbwire Bill
Old 12-01-2003, 02:37 PM
Thanks guys that's a big help. For some reason I never thought of measuring with the dial callipers?!
Old 12-03-2003, 12:14 PM
epatsellis is on a distinguished road
On really big routers, like my 8' x12', the easiest thing to do is drill 4 1/8" holes about 1" in from the extremes, e.g.
peck at 1,1; peck at 1, 143, peck at 95, 143, peck at 1, 95.
insert short pieces of 1/8" drill rod or pins, and measure with a tape measure carefully....out of square is real obvious in the difference in the diagonals.
if you don't want to drill, tightly tape down 4 sheets of paper and chuck a pen in the collet.
tape measure not accurate enough you say, diagonal measures about 171 inches, you can estimate to at least 1/64th of an inch on a 32nd graduated tape, you'll be so close it'll scare you....1/64th at 171 inches is 1 in 10, 944. Acucurate enough????
One other thing, after squaring your axis, you should tram the spindle with a dial indicator, try for .001 in a 6-10" circle, this is very critical when hogging out areas, as the slightest misalignment will show up in the work as tell tale signs of where the cuts overlap.
erie
How do I gang axes? X X Y Z not working. Javelin276 LinuxCNC (formerly EMC2) 4 03-06-2005 09:32 PM
Timing belts for x and y axes (what pitch?) dowling177 Mechanical Calculations/Engineering Design 2 01-27-2005 09:12 AM
Unrestrained axes chuckknigh DIY-CNC Router Table Machines 5 09-13-2004 01:52 PM
can anyone explane all 8 axes? zander1 General CAM Discussion 11 07-08-2004 10:50 AM
Multiple Axes Readouts squarewave CamSoft Products 2 12-12-2003 01:02 PM
