  #61   Ban this user!
Old 06-08-2008, 02:27 PM
dmoore is on a distinguished road
MechMate Bill of Materials Released
To those considering a MechMate, I have released a very detailed bill of materials - six, 8 point font, 11" x 17" pages worth. It includes EVERY part (paint, screws, bolts, steel, etc) and the supplying vendor to build the table and all the major electrical (drivers, wire, switches, etc) parts. The BOM also contains drawing-by-drawing times and tools required.
The basic cost of the MechMate is as follows:
  • Table+motors: $4,500 USD
  • Drivers+electronics+laser (less CAD/CAM): $3,000 USD
  • Dust Management: $500 USD
  • The total cost of a complete MechMate without a spindle or vacuum table, is about $8,500 USD. This easily puts the MechMate on par with commercial units in the $15,000 to $20,000 USD range.
The total physical build time for the MechMate is about 100 hours with the proper tools and skills. There is no cost for the plans which can be found here.
Hope this helps...
david
  #62   Ban this user!
Old 06-08-2008, 02:37 PM
MechMate YouTube Videos
Here are some videos taken of my MechMate prior to being painted:
  #63   Ban this user!
Old 10-31-2008, 03:00 PM
Gerald_D is on a distinguished road
Some comments and pictures from MechMate builders around the world . . .
Here is a "feel good" thread that I assembled from posts of MechMate builders around the world:
http://www.mechmate.com/forums/showthread.php?t=944
Hope that it may inspire some folk to take the plunge . . . it is not as daunting as it may at first appear, and it does earn its keep.
  #64   Ban this user!
Old 05-03-2011, 01:52 AM
redbu11 is on a distinguished road
Bit of an old thread....
I'm looking at various designs for linear motion. I'm leaning towards V-bearings similar to Shopbot and Mechmate. I just have a question regarding the 6 V-bearings on the Mechmate.
6 rollers on the Z-slide (4 rollers will reduce z-range by 50mm [2"]
Are the 6 rollers just for increasing the range? I'm only looking for about 6" of Z-travel, so will 4 rollers do? I would think I would be good with 4 V-bearings, but I'm questioning myself as the Mechmate has gone to 6 and the Shopbot had changed the design of how they utilize the V-bearings.
Thanks for any advice
  #65   Ban this user!
Old 05-03-2011, 03:41 AM
The 6 rollers allows the z-slide to be retracted higher, so that it only sits in the upper 4 bearings. That is sufficient because the slides protrusion/extension below the last supporting bearing is small. When the slide moves down and protrudes out "long" then another pair of bearings take the load lower down.
  #66   Ban this user!
Old 05-04-2011, 01:19 AM
william1384 is on a distinguished road
MechMate CNC Router Forum
LOL
"You are not logged in or you do not have permission to access this page."
I guess I need to signup with them in order to get inspired
  #68   Ban this user!
Old 08-23-2011, 11:02 PM
602CNC is on a distinguished road
Why is this in the open source forum if it costs $100 for the plans?
Old 08-24-2011, 06:17 AM
ger21's Avatar
Because it used to be free.
