Old 07-04-2006, 08:41 PM
Woodie1 is on a distinguished road
Angry Speed
I built a router from plans I got from Bob Campbell I used 3/4 Amce
rod for the Z & Y axis.
The Z& Y axis move slow when I jog them useing the Joy stick ( I'm
useing Dave's Kush Arcsin).
Will that change when I use software? Or should I use better screws?
Thanks,
Old 07-04-2006, 10:14 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
nothing wrong with using the 3/4 screws you have 6tpi will gain you speed as compared to other screws with a higher tpi
i have the same screws as well and i would never go to a lesser size screw
what kind of driver are you using
could be a power supply issue (need more voltage)
how big are the motors and the table
you ll need to give some specs before anyone can answer your questions
Old 07-04-2006, 10:24 PM
I'm using Dave Kush's Arcsin and Slo-syn KML 063 350 oz torque. The power supply puts out abouth 34 v.
I don't have any software yet!
Old 07-04-2006, 10:32 PM
dertsap's Avatar
Gold Member
i would think those motors should have things moving relatively quick , maybe try some of the demo software out there like mach or kcam ,that would probably be the best way to test it
Old 07-05-2006, 02:04 AM
sanddrag is on a distinguished road
there's also TurboCNC. Try that.
Old 07-05-2006, 03:23 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
What voltage are the motors rated for? There's a lot of discussion among the Gecko drive crowd about providing more than the rated voltage for acceleration purposes from the power supply. I think they recommend a 4x factor or something. You'd have to be sure your controllers will do the right thing with extra voltage so as not to burn up the motors though.
BW
Old 07-05-2006, 06:11 PM
The Spec say 3.43 volts 3.3 amps.
Old 07-05-2006, 08:40 PM
vladdy's Avatar
vladdy is on a distinguished road
might just be something as simple as the feed rate setting in jog mode, might just be low..
if not sure, try another piece of software. Kcam is easily configured for a quick test, and is pretty small, no wierd extra software handlers or drivers..
