Old 11-22-2003, 01:41 PM
jleiwig is on a distinguished road
help with info on steppers
I aquired some free steppers, the info on the label is as follows:
Crouzet Servo
82.972.011 Resistance: 2.6 ohms Step: 1.8 degrees P: 14,5w
Can anyone give me any info on decoding this?
Thanks for the help.
Old 11-22-2003, 04:21 PM
motomitch1 is on a distinguished road
Pictures might help and are thay nema 23 size?
Old 11-22-2003, 06:16 PM
chuckknigh's Avatar
Gold Member
chuckknigh is on a distinguished road
Well, 1.8 degrees means that each step is 1.8 degrees. Putting it another way, there are 200 steps per revolution. A nice number...
-- Chuck Knight
Old 11-22-2003, 06:18 PM
balsaman's Avatar
balsaman is on a distinguished road
From ohms law I get they are 6.13 volts, 2.36 amps. They would probably work good with a xylotex board running a 24 volt supply.
Eric
I wish it wouldn't crash.
Old 11-22-2003, 07:08 PM
Eric
There is no way to infer torque ratings is there?
And yes I believe they are either nema23 or possibly nema17. I haven't measured to be sure. They are four wire motors as well
Old 11-22-2003, 07:13 PM
umrk is on a distinguished road
I hope their NEMA34 frame, that should put them in the 250 or more oz/in range. If their NEMA23, they're probably closer to the 125 oz/in range, but typically would be faster motors.
mike
Old 11-22-2003, 07:16 PM
You snuck in while I was typing.
Then their Bipolar. I'd go with Geckos and hit them with 10X (60V) or more If I wanted to use them. But if their NEMA23s they may not suit your needs. If their NEMA17's I wouldn't count on machineing aluminum with them.
NEMA23s are abt 2 1/4" round (square or octal)
NEMA17s are abt 1 5/8" square typically.
mike
Old 11-22-2003, 07:35 PM
mike
I'm almost positive they are nema23s. These will be for a different machine...not my aluminum mill. Just something smaller as a starter project. I'm still getting the 300 oz/in motors for the aluminum mill!
This machine will be mostly wood work and possibly some vinyl cutting if I can figure it out. I think that would be cool because my friend paints cars and some flame stencils would be awesome!
Old 11-22-2003, 08:03 PM
Kool, Power is our friend!
I have considered making a CNC Vinyl cutter, but I talked to a friend tonight and hes giving me a HP D size plotter to try and convert.
mike
Need pulley advice for my steppers mvaughn DIY-CNC Router Table Machines 0 10-08-2004 01:02 PM
Just found some steppers! chuckknigh DIY-CNC Router Table Machines 5 08-14-2004 07:32 PM
steppers and current ullbergm General Electronics Discussion 0 01-29-2004 03:24 PM
Info needed on steppers kayakman DIY-CNC Router Table Machines 3 12-28-2003 10:44 AM
