Old 11-20-2003, 09:45 AM
Hawkeye's Avatar
Hawkeye is on a distinguished road
Single Step/Half Step Question
I am obviously new to all of this CNC stuff. I think I have a solid design for my table (it will be a 24"x36" with an actuall cutting table of 18"x18"), I have my stepper motors, Finally fininshing my controller board...so on and so forth. My question is, On my controller board there for jumpers for Single Step and Half Step, What is the difference, and would this be something that I would want to be able to control (switches) on the outside of my controller case.
Thanks For Your Help,
George
Old 11-20-2003, 10:03 AM
balsaman's Avatar
balsaman is on a distinguished road
set the jumpers and leave them. Try them both to see what you like better. Half step will make your motors make a half step per pulse from your computer. ie. 200 step motor = 400 steps.
Eric
I wish it wouldn't crash.
Old 11-20-2003, 10:04 AM
limbo is on a distinguished road
Most steppers are 200 steps per revolution. This means that your PC will output 200 pulses for every revolution. When the controller is set at halfstep it will effectively double the amount of possible positions in your stepper and create 400 steps for a revolution. The advantage is that the distance for each individual step is smaller, causing the motor to run quiter and with less resonances. Only if you have a very slow PC and very fast steppers you would need to use fullstep to get max. speed but normally the PC can output steprates far beyond what your steppers can keep up with. You don't need the switches outside the cabinet. Just set it to halfstep and if your PC is fast enough you'll never need to touch it again.
greetings
John
Old 11-20-2003, 10:05 AM
balsaman types faster than I do..
Old 11-20-2003, 10:28 AM
Hawkeye's Avatar
Ahhhh !!! (The light comes on).
Thanks guys for the endless knowledge that you share.
George
G-Code to DXF WayneHill OpenSource Software 200 04-22-2012 09:51 PM
Visual Basic Controller Project dwwright Visual Basic 29 02-14-2011 01:24 PM
Do you have a question regarding step motors? ESjaavik Stepper Motors and Drives 0 03-24-2005 01:51 AM
Ametek motors and step down ratio dowling177 Servo Motors and Drives 5 03-01-2005 12:24 PM
step angle question?? kywoodwrkr DIY-CNC Router Table Machines 7 02-22-2005 10:04 AM
