Hi all: I hope I am posting this in the right area - this forum is huge! I am new to the diy CNC world. I have also began to design/plan and buy some material already (just some scrap aluminum). But my next purchase soon will be a very important one and that is the stepper motors and the controllers, I am not worried about the power supply I will problably make that myself. What I would like my router to do is problably the jack of all thing - a bit of this and that (I hope anyways) such as: engraving plastic or thin aluminum, some wood working, sheet aluminum, and some light milling of thicker aluminum as well. My question finally is what motors and controllers should I use, or for that matter stay away from?? I would even consider a kit and soldering it myself BUT at the same time I really wan't somthing thats going to work well. I also wan't it to work well with software. Currently I use AutoCAD to draw my geometry but thats where my knowlege of this stuff ends.Thanks in advance!
__________________ http://www.dreamtone.org/cnc/Mechanical_Design.JPG |
| gecko is the best bet , the drivers leave room for expanding to larger motors , where as a lot of the others are limited up to 3 amp , i ran 4 amp motors on the fet3 board from stepper world , though it is an ok driver it is limited because you need power resistors , when i decided to upgrade drivers the pickings were nil in the more cheaper drivers to run them motors , i did endless research looking for an alternative , gecko was the best bet ,and i am very pleased in that decision , they cost a bit more than the other drivers but i highly doubt the other one can stand up to these , kits in my opinion are bogus the motors that you get are small or cheaper elsewhere if you search around , i bought a kit from stepper world and though i can t say anything bad about the product or support but if i knew then what i know now i d be 300 bucks richer , trial and error gets expensive ebay has motors a dime a dozen , the money you save on ebay can go toward buying better drivers if your anywhere like me you'll always want bigger and faster , a 3 amp driver doesnt leave much if any room to expand ,so i say gecko |
| Ok Here goes. First take a look at Artsoft (Mach 3) http://www.machsupport.com/artsoft/index/index.htm This software will control your cnc. check out the link's page. As for a brakeout board try campbell design's http://www.campbelldesigns.com/ and http://www.geckodrive.com/ gecko 202's would be my stepper driver of choice. As for stepper motors I have found this guy on Ebay, http://www.kelinginc.net/SMotorstock.html they look good. Bob Campbell also sells some good ones. Best of luck. Last edited by Captain; 06-11-2006 at 06:11 AM. |
| Hey dertsap (Jimi Hendrix - awsome guitar player!) Thanks for you'r info I kinda agree with you about the kits. I also noted on one open type driver board I saw you couldn't use 4 wire motors. Captain: Thanks for the links, though I have been to most of them but I will re-vist Artsoft. Why do you suggest the 202's from Gecko? Both of you recomended gecko and I am thinking perhapes that is the way to go my question is if I go with them say the 202 will I need one for each motor and If I deside on using two motors for my x-axis, you know the high end design thats out there that uses the twin acme screws on each side of the table to move the gantry as seen here two motors for the x-axis will I need a forth driver?? Also if I use the Gecko 202's will I need any other boards (besides the power source) Lets say for like 4 limit switches??
| It's tough to recommend motors for a machine without knowing everything about the machine. Way too many variables involved. You didn't say what size machine, but the miniumum would probably be around 275 oz-in Nema 23's, up to 600+ oz-in Nema 34's. While the smaller motors in this range can usually be driven by a Xylotex or HobbyCNC, the Geckos have the ability to give much better performance by using higher voltage. Adding a breakout board will make wiring your Geckos and limit switches a lot easier. there are quite a few available. As mentioned above, www.campbelldesigns.com www.pmdx.com www.cnc4pc.com
| RMS, To get an appropriate answer, you havn't asked enough of the right questions or provided enough info. You say you want to cut Alum. which is one good clue but how big of a table do you plan on building? What spindle will you be using (dremel vs. full size[HEAVY] router)? Do you need a FAST machine? Are you rich? As a noob myself still I can't tell you the in/oz motor requirement per table size but others can chime in. Sure Geckos are the best (if you meet all the criteria like "you are rich", "You don't have the ability to solder one together", etc., etc.). "Best", now there's a relative term. I have nothing against recommending Geckos to someone if they can afford it. They may be way overkill though. Motor size & controller selection should be based on both short-term AND long-term needs. Keep in mind that chances are that you probably will build a second bigger/better machine. Motors & controller should be based on that machine ("IF" you can afford that right now). Hope this helps, and could you provide more info.? |
id stay away from this guys product , i suggest call before you buy , his number is posted on his site , i called then bought elsewhere , the guy doesn t know much about the products he sells , i notice a lot of people post that link and always say they LOOK good ,which means to me nobody is buying them , as far as being rich and over kill with gecko drivers that is BS the geckos are a good reliable driver they can go big or small in motor size you can easily underpower your system and have to buy everything twice |
I am thinking about Nema 23's 200-275 oz-in and the machine is still in the layout phase but the cutting area will be 28"x18" X (8" approx. z-axiz) and It will be made out of aluminum. ....Thanks for the links!
I am not opposed to a kit or soldering I can handle that, If anyone has had possitive results with one I would like to know, or perhapes what to stay away from. So far it looks like I could go in either direction, but it looks like the Geckos are still looking like the best. Though I would need 4 of the 202 drivers (I think) and thats about $450+ each rated at 7A, 80VDC 10-microstep drive. -Vs- The kit at hobbyCNC is $106 but only rated at 42VDC maximum input voltage, 12VDC minimum input voltage. 24VDC Minimum Recommended Voltage. 3.0 Amps Maximum per Phase, 500ma (.5A) minimum. Each axis adjustable throughout this range. So it looks like the Geckos have 4 times the power so we could say they are a good deal in that sence. ?? anybody?
#10
| If you are making a table that small there is no sense in using two ballscrews on one axis, the reason that they use the tandom ballscrews is if it is a longer table, and it is racking or doing other things that aren't desirable. As long as your linear bearings are good, dual ballscrews won't even help. in a configuration like shown in the link that you posted, it could simplify things a bit, but as far as I can see that is the only advantage. |
#11
| What about this site? http://www.xylotex.com/ they have a few kits and look to be reasonable. 269 oz motors, drivers and power supply for between 345.00 and 420.00.This is where i'm thinking of buying from. Rev. |
#12
Does anyone know for sure? I am leaning more to the one at HobbyCNC.
__________________ http://www.dreamtone.org/cnc/Mechanical_Design.JPG Last edited by RMS; 06-12-2006 at 05:58 PM. |
