Old 06-10-2006, 04:53 PM
billman is on a distinguished road
Newbie..What router to get?
I was looking at a Skil Router Combo 2 1/4HP, 8k - 25k RPM, 11amp, with 1/4 & 1/2" collets (also with a fixed and plunge base) for $99....I read that I won´t need the bases but looks like the best deal for the money.
What do you all think??
Old 06-10-2006, 07:29 PM
I assume the first place to start is getting the right router. I´m looking at doing a gantry type cnc router (if that helps). So, can anyone help me???????? I want to start doing this tomorrow, since I´ve got some free time..
Old 06-10-2006, 07:49 PM
ger21's Avatar
I've never used the Skill. A lot of guys are using the Hitachi, which is about $30 more. If I had to choose between the two, I'd go the Hitachi route. I haven't used the Hitachi either, though. But I think they make a better tool. Probably not a lot of difference, though. If you do go the Skil route, make sure it has a round body that is easy to mount.
Old 06-10-2006, 08:35 PM
Regnar's Avatar
Regnar is on a distinguished road
I am also looking at routers right now for a jgro build and I came across this one at home depot. http://www.coastaltool.com/cgi-bin/w...h/pr20evsk.htm. Although its a trim router you can control the the speed and it does have a 1hp motor in it. Its bigger than a dremel but smaller than a router. I might give it a try
Old 06-10-2006, 08:39 PM
HayTay's Avatar
HayTay is on a distinguished road
Exclamation
Billman,
Are you talking about this one 2 in 1 Router Combo Kit #1825?
Larger Picture of #1825 Router
I would recommend that you steer clear of this router for several reasons:
1. Lower body is not round and it will be more difficult to make a mount to attach it to the Z-axis assembly.
2. The router uses a trigger in one of the handles to power the router on and off. This will have to be defeated with a cable tie or tape. The variable speed control dial is located in the other handle (see reason 3).
3. The handles are a permanent part of the router and not a part of the fixed or plunge base. You may have to design your machine with a larger Y-axis or modified Z-axis to make up for any loss in travel due to the handles sticking out both sides of the router. If you cut off the handles you will have to find some way of enclosing the trigger and speed dial.
I, and many others here on CNCzone, use and recommend the Hitachi 2.25 HP Variable Speed Fixed Base Router, Model #M12VC. It works great and is one of the quieter routers I've used. It's only $15.00 more at Lowe's and is more suited to what you want to accomplish. You can read about it here, follow the links.
Have lotsa fun shopping tomorrow!
HayTay
HayTay
Don't be the one that stands in the way of your success!
Old 06-10-2006, 09:58 PM
thanks..you guys rock! I almost made a big mistake. I will go with the hitachi.
