Old 11-19-2003, 12:41 PM
ljoe1969 is on a distinguished road
Uhmw Or Delrin Or Nylon For Antibacklash Nut?
HI
I wanna make an antibacklash nut and I was wondering on which material to use.
here is a pic of what I am planning.
Old 11-19-2003, 01:11 PM
Gold Member
creative_mind is on a distinguished road
ljoe1969,
How did go about making the anti-backlash nut shown in your CAD drawing?
Are there any springs used?
Can you give me an overall view of it, please.
Old 11-19-2003, 01:25 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Ijoe1969,
That will work Joe.
The threaded portion of the nut is cut half way through and when you tighten the allen bolt shown in your drawing, it will cause the threaded portion of the nut to squeeze together causing reducing or eleminating the play.
Hager
Old 11-19-2003, 01:38 PM
balsaman's Avatar
balsaman is on a distinguished road
Those plastics are similar so I don't think it matters much.
Eric
I wish it wouldn't crash.
Old 11-19-2003, 03:39 PM
Chagrin is on a distinguished road
Of the three, Delrin is probably the best choice due to its low coefficient of thermal expansion.
If you look around, I think you'll find that most anti-backlash nuts are made of Delrin.
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
UHMW vs Delrin vs HDPE rail slides Rance DIY-CNC Router Table Machines 15 01-03-2009 03:16 PM
