Old 11-18-2003, 12:25 AM
Klox's Avatar
Gold Member
Klox is on a distinguished road
Question Haas Gr 510
I saw an advertisement in the Machine Tool Market of Southern Africa of the Haas Gr 510....
It looks like a very capable CNC router, it also looks VERY expensive......
Klox
*** KloX ***
I'm lazy, I'm only "sparking" when the EDM is running....
Old 11-18-2003, 05:51 AM
Moderator
Dan B is on a distinguished road
We bought one back in January. We had it custom built with an additional 6" of Z height. We use it for drilling, reaming, tapping etc.
It has been a great investment, and a very reliable machine.
I believe that we paid $80,000 US. Although it seems expensive, it has paid for itself already. Our process of scribing and drilling fixture bases used to take between 5 to 7 hours doing it manually. We now do it in 1 hour. We have processed abround 1000 bases since January on the Haas. At a 6 hour savings per base, and a shop rate of $50/hour, you can do the math and see that it has paid for itself almost 4 times.
Any specific questions?
Dan
Old 11-18-2003, 09:49 AM
Klox's Avatar
Gold Member
Thanx for the info, I'm the type of guy that would prefer to drive a banger & use my excess funds to buy tools!
You know the saying: "The difference between men & boys are the price of their toys"
What size holes can you drill with the Gr 510?. The scribing: Please tell me more about how you go around doing it (Please remember I'm an EDM idiot! LOL).
Klox
*** KloX ***
Old 11-18-2003, 10:00 AM
Moderator
Hi Klox,
We typically drill holes up to 3/4" in alum. or steel. We tap up to 3/8 in steel, but find that the HP isn't there for tapping over that size. The Haas will do it, but it's working way too hard.
As for scribing, it's probably more fitting in this forum to call it engraving. I create my engraving paths in Rhino, then process them with Worknc. We usually make 2 passes in alum, and 4 in steel to get the desired depth.
All holes are processed directly from Rhino, using a program I wrote in VB. Interestingly, we are also doing 5-axis drilling and simultaneous 5-axis cutting directly out of Rhino too, without the use of any CAM programs. Admittedly, the simultaneous cutting is limited, but we can do it (usually an engraving path over a contoured surface)
Dan
Haas Lathe Reccomendations imwllc Haas Mills 17 04-05-2012 12:21 PM
Recommendation for HAAS jbo Haas Mills 10 09-19-2005 07:30 AM
HAAS mini lathe marto74 Haas Lathes 4 01-15-2004 11:55 AM
Searching Backwards jonbanquer Fadal 11 07-28-2003 06:53 PM
HAAS Indexer Prodramming / Control CAMmando Haas Mills 8 06-10-2003 10:22 AM
