Two quick questions: a) Which instrument would you recommend using to debug the printer port output, an oscilloscope or a logic analyzer?? I'm using turbocnc for the first time. b) Is there a tool/sensor that measures whether the servomotor has moved a certain distance? Thanks in advance, Hani A. |
| Well, let's see here... for a) O-Scope, $3000 Logic Analyzer $5000 Transistor/Resistor/LED 98 cents Tough choice here but I'd go with a simple LED circuit Seriously, I'd say you could do about 98% of what you need to do with a simple LED circuit. It doesn't even have to incorporate a perf board. Initially you only need to know the levels of the pins. Later when you are dealing with timing issues, you can start out slow and slowly ramp up the speed, then back off just a little after it starts failing. My 2c worth |
| Rance is right. If you want to get fancy about the LED approach, try something like this: http://www.stayonline.com/detail.aspx?ID=7514 Using Mach 3 at the computer end (somebody probably makes a purpose built gadget too), you can turn the pins on and off as well. Best, BW |
